Started on aluminum first cuts ever
I have considered it but its just that I have been trying to avoid cutting fluid because I didn’t want it to soak into the table and potentially stain any future wood projects, I was hoping i could just run it slow enough for the bit to stay cool, but I do think wd-40 would do wonders for its cutting ability & I do think I will use some soon, I would love a oil drip for it on the opposite side of the vacuum but i still have it in table format so i need to build a new design for the tilting ability because I used the M4 Hourglass Frame (which is an amazing frame that I honestly think should be added to the wiki if it hasn’t already been because its such a good table design but it hasn’t had a tilt table designed for it yet from what i can tell its just been used as a table so far, if anyone knows of a frame for the frame that would work on it to tilt it up please lmk, I will be designing and making one for it soon tho, I’m excited to share whatever design I come up with, I’m thinking like the ratchet gear design that they use for drawbridges made out of some wood possibly sandwiched between aluminum on both ends
