Been having issues with connectivity, but I think I mostly solved them by turning connection monitoring off and going into AP mode. I was having some messages about a corrupted maslow.yaml so I updated to most recent firmware. Went through the process to retract, extend, place anchors, calibrate, home, and then load and hit play. Fluid NC began tracking the movement of the sled, but the sled wasn’t moving in reality. Gave me this read out:
JogTo: $J=G91F2500X-783.53Y-433.53 (mm)
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 20.947mm Counter: 1]
[MSG:WARN: Previous error was 20.947mm]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 51.004mm Counter: 1]
[MSG:WARN: Previous error was 51.004mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 20.947mm Counter: 2]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 51.004mm Counter: 2]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 20.947mm Counter: 3]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 51.004mm Counter: 3]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 20.947mm Counter: 4]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 51.004mm Counter: 4]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 20.947mm Counter: 5]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is 51.004mm Counter: 5]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 20.947mm Counter: 6]
[MSG:ERR: Position error > 15mm while running. E-Stop triggered.]
JogTo: $J=G91F2500X-89Y-84.94 (mm)
Turned it off and on again. Thought it would just rehome since the firmware update, but it didn’t. Went through the unanchor, retract, extend, reanchor, apply tension process. Homed successfully. Went to move the home to the origin of the gcode I wanted to cut. And one of the belts snapped.
Ordering another belt now, but not looking forward to the process of disassembling and replacing the belt if all I get for my troubles are more problems running a file. What am I messing up here?
