Position error, exceeded 15mm while running
Finished calibrating. I’m able to jog, but it won’t even let me begin a dry run without giving me this error code. Im a complete beginner to all of this, so any help is appreciated.
[MSG:INFO: Tool No: 1]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is -1826.719mm Counter: 1]
[MSG:WARN: Previous error was -1826.719mm]
[MSG:WARN: Position error on Top Right axis exceeded 15mm while running. Error is -1820.715mm Counter: 1]
[MSG:WARN: Previous error was -1820.715mm]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is -1831.319mm Counter: 1]
[MSG:WARN: Previous error was -1831.319mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -1835.524mm Counter: 1]
[MSG:WARN: Previous error was -1835.524mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is -1826.719mm Counter: 2]
[MSG:WARN: Position error on Top Right axis exceeded 15mm while running. Error is -1820.715mm Counter: 2]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is -1831.319mm Counter: 2]
Which firmware version are you using? I remember a bug like this a while back, but I believe that it should be fixed in the latest version.
I was on 1.04 firmware. I updated it to 1.23… I think? I’m not sure what I did wrong, but now it won’t let me jog or do much at all. It also says “State: Unknown”. In addition, the green play button next to the red stop button is gone and blank.
Serial Messages
Index.html Version: v1.23.0
[MSG:INFO: FluidNC v1.23.0]
[MSG:WARN: Ignored key cs_pin]
[MSG:WARN: microsteps value 0 constrained to range (1,256)]
[MSG:INFO: Machine Default (Maslow S3 Board)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 5]
[MSG:INFO: Axis A (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-1000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: tmc_2209 UART1 Addr:0 Step:gpio.15 Dir:gpio.16 Disable:NO_PIN R:0.11]
[MSG:INFO: Motor1]
[MSG:INFO: tmc_2209 UART1 Addr:1 Step:gpio.46 Dir:NO_PIN Disable:NO_PIN R:0.11]
[MSG:INFO: STA SSID is not set]
[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: WebSocket send protection active (canSend() checks enabled)]
[MSG:INFO: Captive Portal Started]
Grbl 1.23 [FluidNC v1.23.0 (wifi) ‘$’ for help]
[MSG:INFO: ‘$H’|‘$X’ to unlock]
[MSG:INFO: Current z-axis position loaded as: 0.000]
[MSG:INFO: Saved belt positions in NVS are marked as stale/invalid (value=0) - machine will remain in UNKNOWN state until belts are calibrated/extended]
[MSG:INFO: Starting Maslow Version v1.23.0-dirty]
[MSG:INFO: Maslow_Retract_Current_Threshold: 1300]
[MSG:INFO: Maslow update loop registered with hardware watchdog]
[MSG:INFO: Zm=0.000mm, Z home=0.000mm, Z position=0.000mm]
Retract All
error:152 - Configuration is invalid. Maslow.yaml file may be corrupt. Turning off and back on again can often fix this issue.
Z Home pos set: Z=15mm
JogTo: $J=G91G21F300Z-5 (mm)
Maslow is not ready to move.
Could not perform Jog. Belt lengths are unknown.
Save a copy of your maslow.yaml file if you haven’t already and replace it with the new version in V1.23. You will then need to rerun Find Anchors or manually update the maslow.yaml file with the Anchor point values from you existing maslow.yaml file.
  1. Got to FluidNC
  2. Click on Config Items
  3. Go down to /kinematics/MaslowKinematics/tlX
  4. Copy each value from your old maslow.yaml into the corresponding position in the new maslow.yaml
  5. Set each value
  6. go to top again and save
I recommend a power reset, then you will then need to retract, extend and apply tension
Thank you for the quick response. I tried the things you said, however, I must’ve done something wrong. Because after 3rd time of attempting that process, I went to jog and the machine just started going straight down (I have it mounted vertically) with no sign of stopping until I unplugged the machine. Also, I’m not sure if this matters, but I’m doing all of this on a Mac. If you or anyone else has any answers, that would be greatly appreciated. Thank you
Serial Messages
Index.html Version: 1.04
[MSG:INFO: Axis A (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: WiFi on]
[MSG:WARN: Maslow Z position warning: Z position out of range, check Z home is val Step:gpio.15 Dir:gpio.16 Disable:NO_PIN R:0.11]
[MSG:INFO: Motor1]
[MSG:INFO: WiFi on]
[MSG:WARN: Maslow Z position warning: Z position out of range, check Z home is val[MSG:INFO: Maslow update loop registered with hardware watchdog]
[MSG:INFO: Maslow_Retract_Current_Threshold: 900]
[MSG:ERR: Invalid setting or command: /Maslow_Calibration_Current_Threshold]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_beltEndExtension]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_armLength]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_trX]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_trY]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_trZ]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_tlX]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_tlY]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_tlZ]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_brX]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_brZ]
error:3
[MSG:ERR: Invalid setting or command: /Maslow_blZ]
error:3
JogTo: '$J=G91F2500X100Y-100
JogTo: '$J=G91F2500X-100Y100
error:3
error:3
error:3
error:3
error:3
error:3
error:3
error:3
error:3
Test
[MSG:INFO: Firmware Version: v1.23.0-dirty]
[MSG:INFO: I2C Timeout: ]
[MSG:INFO: 10]
[MSG:INFO: All tests passed on Top Left]
[MSG:INFO: All tests passed on Top Right]
[MSG:INFO: All tests passed on Bottom Left]
[MSG:INFO: All tests passed on Bottom Right]
[MSG:INFO: Unable to determine machine position from belt lengths]
Stop Maslow and Gcode
Do you have the control board upside down, The power cord must be pointing down when on a vertical orientation.
Also your index.html.gz is the old version. You will need to update it to the V1.23.
FluidNC
First Green button (Manage Local Files) and load the latest version of index.html.gz. On the Mac when you download it wants to unpack the file. You need to load the compressed (gz) version of the file. Try right click when down loading from resources.
It is going to be the wrong version causing the problem
Can you put a copy of your maslow.yaml file up here please
Its very particular regarding the formatting
The power cord is pointing down. I noticed that the index.html.gz is the old version. However, when I try to put the updated one in, it seems not to change anything. It must be because of what you’re saying about it wanting to unpack. The thing is, I read about that somewhere and tried to do what you’re saying, but I couldnt seem to get it to work. Also as I write this, the interface crashed and will no longer open. Not even when I search “192.168.0.1”. The light is a constant green and there are no blinking red or blue lights.
maslow.yaml (6.6 KB)
These are what my screens look like when I type maslow.local and 192.168.0.1
No blinking blue light means that the machine is not connected to the wifi and is creating its own “Maslow” wifi network. You should be able to connect directly to that wifi network to get the connection back.
I was able to regain access to the Maslow interface. I retracted/extended the belts. Put it back on my frame, pressed the apply tension button. Uploaded the gcode, however, my play button is non-existent. So even if I wanted to, I couldnt attempt to start it. I then pressed the square stop button, and it told me belt lengths were unknown.
Serial Messages
[MSG:WARN: Ignored key MaslowAutoUpdate]
[MSG:WARN: Ignored key MaslowUpdateURL]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: WiFi on]
[MSG:INFO: Current z-axis position loaded as: 15.000]
[MSG:INFO: No saved belt positions found in NVS - machine will remain in UNKNOWN state until belts are calibrated/extended]
[MSG:INFO: Zm=15.000mm, Z home=0.000mm, Z position=15.000mm]
Retract All
[MSG:INFO: Caution: Unlocked]
[MSG:INFO: Succeeded]
[MSG:INFO: Top Right pulled tight with offset -2210.768]
[MSG:INFO: Top Left pulled tight with offset -2188.707]
[MSG:INFO: Bottom Right pulled tight with offset -2623.204]
[MSG:INFO: Bottom Left pulled tight with offset -2749.456]
Extend All
[MSG:INFO: All belts extended to 2600.000mm]
Extend All
[MSG:INFO: Requesting state change from Belts Extended to Extending Belts]
[MSG:INFO: All belts extended to 1900.000mm]
Retract All
[MSG:INFO: Requesting state change from Belts Extended to Retracting Belts]
[MSG:INFO: Bottom Left pulled tight with offset 0.000]
[MSG:INFO: Top Right pulled tight with offset 0.129]
[MSG:INFO: Top Left pulled tight with offset -0.365]
[MSG:INFO: Bottom Right pulled tight with offset -0.032]
Retract All
[MSG:INFO: Requesting state change from Belts Retracted to Retracting Belts]
[MSG:INFO: Top Right pulled tight with offset -0.086]
[MSG:INFO: Bottom Right pulled tight with offset 0.000]
[MSG:INFO: Top Left pulled tight with offset -0.064]
[MSG:INFO: Bottom Left pulled tight with offset -0.032]
Extend All
Apply Tension
[MSG:INFO: Requesting state change from Belts Extended to Taking Slack]
[MSG:INFO: Waypoint 0 coordinates: X=0.000 Y=ovf]
[MSG:INFO: Unable to determine machine position]
[MSG:ERR: Failed to compute XY from lengths]
Test
[MSG:INFO: 10]
JogTo: $J=G91G21F300Z5 (mm)
Z Home pos set: Z=0mm
[G54:0.000,0.000,0.000,0.000,0.000]
Z Home value clamped to range: Z=72
Z Home pos set: Z=72mm
[G54:0.000,0.000,72.000,0.000,0.000]
Home pos set: X=0 Y=0
[MSG:INFO: Zm=85.000mm, Z home=72.000mm, Z position=13.000mm]
Retract All
Set Z-Stop
Stop
It looks like the machine doesn’t have a good understanding of the anchor point locations. Running locate anchors or copying them over form an old .yaml file should fix that
How would I go about this? The “find anchor locations” button is grayed out and I tried clicking it anyway and it gave me a message saying to make sure the Z is all the way lowered. So i go to lower it and it gives me a low z warning but lowers anyway. I got it lowered all the way to the point of it bottoming out, but the find anchor locations button is still grayed out.
It looks like the versions now match. If you have the old version of maslow.yaml you can copy the position data as per the how I put up above OR
I suggest you start by
  1. disconnectinng anchors,
  2. click Setup
  3. Retract,
  4. Extend
  5. Reconnect to anchors
  6. Find Anchors
Thank you, this helped. I was doing the steps in the wrong order it seems
