Hi all. Okay, I finally got my machine through calibration and I attempted to cut my first file. There were some issues. Z did not seem to follow the programmed depth per pass. My material was 1/4" ply so I set the depth per pass at .125" (I’m using Easel for my gcode generation). I set the feed to 50"/min and the plunge at 20"/min. Sled speed seemed to be fine but Z plunged the bit all the way through the material which caused the whole machine to vibrate violently and ultimately knocked the power cord loose. I decided to try again but ran into more issues - Z went absolutely nuts and slammed all the way through the entire material and well into my spoil board. That said, here are my [probably] dumb questions.
- Is there a Z calibration that needs to be done?
- Does Z home need to be defined before every new cut?
- Is there a global “home” for all axis that will take you back to where the calibration was set?
- Does retract/extend need to be done every time the machine power cycles and/or looses connection to the computer? I lost connection and the machine wouldn’t move citing “unknown belt length”.
- I have a vertical set up. Is it not recommended to leave the machine up? Should I always take the machine down after using?
- What are the recommended max speeds for Maslow 4?
