Testing Requested alternate calibration calculation
This uses a different way of calculating the anchor point locations from the points measured. It is MUCH faster (deliberate pauses set in the system take more time than the calculations) and instead of a ‘fitness’ score, it provides ± distance error bars for each measurement.
It also throws out measurements that are in significant disagreement from the rest of them.
To test this, load
index.html.gz (127.0 KB)
in the preferences menu (under the top right menu button) there is a new option for calibration algorithm, it defaults to Maslow Classic, but there is an option Gauss-Newton… that enables the new calculations.
  1. save your maslow.yaml file
  2. load the new index.html
  3. restart (it’s possible that just reloading the page may work, but browsers cache stuff
  4. do a calibration using Maslow-Classic
  5. save the logs
  6. save your maslow.yaml file
  7. do a calibration using Gauss-Newton
  8. save the logs
  9. save your maslow.yaml file
If the new calculations don’t work, calibration may hang or start throwing errors. If this happens, just restart the maslow (save the logs first) and go back to your original maslow.yaml file (rebooting after loading it)
what we will then want to do is to compare the anchor point locations recorded (and the fitness/errors reported) in the log file.
We also want a report of how the machine works after this. when you jog around, are the belts properly tight, how is the accuracy (especially compared to the maslow-classic algorithm)
Just this basic testing will be incredibly useful.
For those who have time to run more calibrations using the new algorithm, more experimentation can be done
Now that we have anchor point accuracy that we can understand, and it is supposed to throw away bad points, we can experiment with things to find out more about what is needed in terms of grid size and grid area.
My guess is that a larger grid area will help more than more points in a given area.
People who have frames where they can easily go ‘out of the green’ (i.e. to areas where the arms hit the belts) or who have seen areas of the machine where accuracy really suffers (probably edges/corners) can test grid areas that include these problem areas and see if it throws away the points there. This may require more points for it to notice how bad those areas are.
It would also be worth testing what happens if a belt catches on something (say dust collector, corner of workpiece, your foot…) and isn’t straight when it’s measured (in theory, that data point should be thrown out, does it work reliably)
for people with huge frames, I would not be surprised to find that a 3x3 grid that covers the entire work area gives numbers just as accurate as doing a 9x9 grid
Is there an option to test it offline, like a simulator? It would be cool to throw a bunch of old data at it and see how it handles different situations without needing to run it on an actual machine
another thing that is useful for people to do.
When the maslow does a calibration, it logs CLBM lines, reporting the belt
lengths that it has measured. Please paste this data into this online calculator
this uses the new algorithm to report what it thinks the anchor loations are.
Then report the CLBM line followed by the calculation results
(this all happens in your browser, so I can’t log the data server-side)
  • how do the results that this reports compare to what your maslow.yaml says?
  • how bad are the ± values for the data?
  • how much does throwing out outliers help?
  • do you get a ‘failed to converge’ message
For people who have logs of when the old calibration failed (especially with
extremely low fitness), does this version give a reasonable result? does it
throw out some points in doing so?
@bar, can we scrape the forums and find CLBM lines posted (or put in
attachments) and extract them?
I was just posting a way to do that :slight_smile:
I also have what grok claims is a C program that should take the CLBM data as an
input, but it’s not quite working. I may give it another try.
In the meantime, see what you can extract from the forums.
I purged ~100k deleted messages from my inbox about a week ago, if I had held
off, I could just dig through my inbox :slight_smile:
the first 7 posts (other than this thread) that had CLBM in them
errors-in-serial-file-after-firmware-update-to-1-12/24965/21
was stuck with fitness 0,5
Adaptive Init:
x1: 2184.9 mm, x2: 3296.4 mm, y2: 1966.9 mm, x3: 1092.4 mm, y3: 1966.9 mm
Outliers at indices: [0]
Threshold: 1.845 mm
Dismissed Outlier Points:
Index 0: {bl: 1947.85, br: 1986.04, tr: 2205.33, tl: 2164.45} (BR error: 0.30 mm, BL error: 2.25 mm)
Full Fit:
x1 (B): 3344.3 ± 58.7 mm
x2 (C): 3335.0 ± 55.1 mm, y2 (C): 2450.6 ± 75.0 mm
x3 (E): 1.8 ± 8.0 mm, y3 (E): 2447.1 ± 73.3 mm
Residual sum: 33485.136 mm²
Cleaned Fit (no outliers):
x1 (B): 3291.9 ± 44.9 mm
x2 (C): 3285.5 ± 43.3 mm, y2 (C): 2516.6 ± 56.4 mm
x3 (E): 2.6 ± 5.1 mm, y3 (E): 2517.8 ± 54.6 mm
Residual sum: 17566.614 mm²
software-and-calibration-trouble/24932/29
initial 6 reporting as fitness 2
Adaptive Init:
x1: 2096.6 mm, x2: 3169.8 mm, y2: 2068.3 mm, x3: 1048.3 mm, y3: 2068.3 mm
Threshold: 1.003 mm
Index 0: {bl: 2043.43, br: 2093.26, tr: 2099.31, tl: 2093.84} (BR error: 1.24 mm, BL error: 1.62 mm)
Full Fit:
x1 (B): 3507.7 ± 60.7 mm
x2 (C): 3538.1 ± 63.7 mm, y2 (C): 2235.6 ± 100.8 mm
x3 (E): 15.7 ± 5.3 mm, y3 (E): 2225.4 ± 99.1 mm
Residual sum: 28170.374 mm²
x1 (B): 3486.3 ± 22.2 mm
x2 (C): 3512.9 ± 23.3 mm, y2 (C): 2274.4 ± 36.0 mm
x3 (E): 19.8 ± 2.1 mm, y3 (E): 2264.1 ± 35.3 mm
Residual sum: 8886.704 mm²
continuing to 14
Adaptive Init:
Threshold: 1.211 mm
Index 0: {bl: 2043.43, br: 2093.26, tr: 2099.31, tl: 2093.84} (BR error: 0.68 mm, BL error: 1.37 mm)
Full Fit:
x1 (B): 3489.5 ± 32.3 mm
x2 (C): 3520.2 ± 33.7 mm, y2 (C): 2264.8 ± 52.3 mm
x3 (E): 16.5 ± 2.7 mm, y3 (E): 2255.4 ± 51.2 mm
Residual sum: 64810.035 mm²
x1 (B): 3482.2 ± 29.9 mm
x2 (C): 3512.1 ± 31.2 mm, y2 (C): 2277.2 ± 48.1 mm
x3 (E): 17.8 ± 2.5 mm, y3 (E): 2268.4 ± 47.0 mm
Residual sum: 57825.004 mm²
continuing to 30 (still fitness 2)
Adaptive Init:
Outliers at indices: [5]
Threshold: 1.618 mm
Index 5: {bl: 1921.10, br: 2221.64, tr: 2220.98, tl: 1968.87} (BR error: 1.77 mm, BL error: 1.27 mm)
Full Fit:
x1 (B): 3473.6 ± 9.3 mm
x2 (C): 3506.0 ± 9.7 mm, y2 (C): 2287.5 ± 14.8 mm
x3 (E): 20.9 ± 1.2 mm, y3 (E): 2286.3 ± 14.4 mm
Residual sum: 140593.721 mm²
x1 (B): 3471.5 ± 8.6 mm
x2 (C): 3504.5 ± 9.0 mm, y2 (C): 2289.9 ± 13.7 mm
x3 (E): 21.0 ± 1.2 mm, y3 (E): 2289.7 ± 13.4 mm
Residual sum: 125347.145 mm²
calibration-failure-cant-get-fitness-above-like-0-2/24517/9
initial 6 fitness 0.19 evolving to 0.89 over >30000 iterations, new solver failed for CLBM:[{bl:1804.91, br:1818.25, tr:2252.67, tl:2251.37},{bl:1919.08, br:1710.85, tr:2162.84, tl:2344.22},{bl:2000.99, br:1790.56, tr:2045.39, tl:2245.25},{bl:1900.29, br:1902.68, tr:2128.03, tl:2141.46},{bl:1791.38, br:2015.25, tr:2228.09, tl:2043.40},{bl:1688.11, br:1946.61, tr:2348.36, tl:2152.35},]
maslow continued to 14 points fitness 0.8
Adaptive Init:
x1: 2252.0 mm, x2: 3384.7 mm, y2: 1811.6 mm, x3: 1126.0 mm, y3: 1811.6 mm
Threshold: 1.642 mm
Index 0: {bl: 1804.91, br: 1818.25, tr: 2252.67, tl: 2251.37} (BR error: 3.55 mm, BL error: 0.69 mm)
Full Fit:
x1 (B): 3167.8 ± 9.3 mm
x2 (C): 3172.4 ± 8.8 mm, y2 (C): 2491.3 ± 11.4 mm
x3 (E): 10.1 ± 1.6 mm, y3 (E): 2484.8 ± 11.4 mm
Residual sum: 79427.516 mm²
x1 (B): 3176.4 ± 7.0 mm
x2 (C): 3182.2 ± 6.7 mm, y2 (C): 2478.8 ± 8.8 mm
x3 (E): 10.9 ± 1.2 mm, y3 (E): 2474.6 ± 8.8 mm
Residual sum: 55874.206 mm²
fitness 0.8
Adaptive Init:
Outliers at indices: [0, 15]
Threshold: 1.565 mm
Index 0: {bl: 1804.91, br: 1818.25, tr: 2252.67, tl: 2251.37} (BR error: 3.86 mm, BL error: 0.71 mm)
Index 15: {bl: 1870.62, br: 1864.23, tr: 2168.05, tl: 2190.37} (BR error: 2.85 mm, BL error: 0.65 mm)
Full Fit:
x1 (B): 3169.0 ± 9.8 mm
x2 (C): 3174.2 ± 9.3 mm, y2 (C): 2489.1 ± 12.0 mm
x3 (E): 10.4 ± 1.7 mm, y3 (E): 2483.7 ± 12.0 mm
Residual sum: 91449.243 mm²
x1 (B): 3176.0 ± 6.7 mm
x2 (C): 3181.8 ± 6.5 mm, y2 (C): 2479.2 ± 8.4 mm
x3 (E): 10.9 ± 1.1 mm, y3 (E): 2475.3 ± 8.4 mm
endless-calibration-always-gets-stuck-in-bottom-right-corner-lifting-sled-unsure-where-to-go-now/24479/5
fitness started very low, eventually got to 1
initial 6
x1: 1952.1 mm, x2: 2925.5 mm, y2: 1900.1 mm, x3: 976.0 mm, y3: 1900.1 mm
Outliers at indices: []
Threshold: 1.266 mm
No outliers detected.
Full Fit:
x1 (B): 2911.6 ± 38.6 mm
x2 (C): 2897.0 ± 39.8 mm, y2 (C): 2533.6 ± 45.4 mm
x3 (E): -6.3 ± 3.4 mm, y3 (E): 2518.5 ± 45.8 mm
Residual sum: 16540.517 mm²
at 14 fitness 0.79
Adaptive Init:
Outliers at indices: [3]
Threshold: 2.267 mm
Index 3: {bl: 2011.00, br: 2002.84, tr: 1846.48, tl: 1851.66} (BR error: 0.34 mm, BL error: 2.91 mm)
Full Fit:
x1 (B): 3096.4 ± 20.9 mm
x2 (C): 3098.4 ± 21.7 mm, y2 (C): 2283.5 ± 29.2 mm
x3 (E): -9.4 ± 3.0 mm, y3 (E): 2283.9 ± 28.6 mm
Residual sum: 115910.842 mm²
x1 (B): 3116.3 ± 20.2 mm
x2 (C): 3118.6 ± 20.8 mm, y2 (C): 2256.1 ± 28.6 mm
x3 (E): -8.1 ± 2.7 mm, y3 (E): 2258.9 ± 27.9 mm
Residual sum: 101244.651 mm²
at 30 it did not complete
Adaptive Init:
Outliers at indices: [28, 29, 30]
Threshold: 8.253 mm
Index 28: {bl: 2375.07, br: 1570.49, tr: 1522.93, tl: 2355.93} (BR error: 10.20 mm, BL error: 5.08 mm)
Index 29: {bl: 2321.80, br: 1486.27, tr: 1609.75, tl: 2413.06} (BR error: 11.63 mm, BL error: 3.78 mm)
Index 30: {bl: 2273.91, br: 1402.30, tr: 1701.28, tl: 2475.39} (BR error: 10.89 mm, BL error: 0.76 mm)
Full Fit:
x1 (B): 3069.0 ± 11.9 mm
x2 (C): 3057.3 ± 12.5 mm, y2 (C): 2342.2 ± 15.8 mm
x3 (E): -1.0 ± 3.5 mm, y3 (E): 2330.4 ± 16.0 mm
Residual sum: 711593.214 mm²
x1 (B): 3079.4 ± 11.3 mm
x2 (C): 3072.9 ± 12.2 mm, y2 (C): 2320.9 ± 15.8 mm
x3 (E): -5.6 ± 3.6 mm, y3 (E): 2311.9 ± 14.5 mm
Residual sum: 516682.461 mm²
fitness-not-close-not-converging/24515/30
initial 6 fitness started very low eventually got to 0.7 after MANY restarts
Adaptive Init:
Threshold: 8.253 mm
Full Fit:
at 16 points fitness 0.9
Adaptive Init:
x1: 2252.2 mm, x2: 3369.6 mm, y2: 2167.2 mm, x3: 1126.1 mm, y3: 2167.2 mm
Outliers at indices: [4, 13]
Threshold: 2.081 mm
Index 4: {bl: 2175.77, br: 2365.39, tr: 2259.40, tl: 2042.97} (BR error: 0.12 mm, BL error: 2.14 mm)
Index 13: {bl: 2307.43, br: 2131.18, tr: 2117.78, tl: 2280.54} (BR error: 1.31 mm, BL error: 2.41 mm)
Full Fit:
x1 (B): 3683.8 ± 30.9 mm
x2 (C): 3676.8 ± 31.7 mm, y2 (C): 2431.9 ± 48.2 mm
x3 (E): -41.1 ± 2.9 mm, y3 (E): 2389.6 ± 47.4 mm
Residual sum: 116499.568 mm²
x1 (B): 3675.4 ± 27.6 mm
x2 (C): 3668.8 ± 28.4 mm, y2 (C): 2443.9 ± 42.9 mm
x3 (E): -44.2 ± 2.6 mm, y3 (E): 2397.9 ± 41.9 mm
Residual sum: 86247.495 mm²
not-sure-what-to-try-next/24447
initial 6 took many tries to get to fitness 0.6
Adaptive Init:
x1: 1872.0 mm, x2: 2805.0 mm, y2: 1863.0 mm, x3: 936.0 mm, y3: 1863.0 mm
Threshold: 1.813 mm
Full Fit:
x1 (B): 2878.1 ± 50.2 mm
x2 (C): 2870.8 ± 52.1 mm, y2 (C): 2380.3 ± 62.6 mm
x3 (E): -13.5 ± 5.4 mm, y3 (E): 2367.8 ± 63.2 mm
Residual sum: 26587.370 mm²
at 16 fitness 0.56
Adaptive Init:
Outliers at indices: [13, 14]
Threshold: 2.271 mm
Index 13: {bl: 2098.18, br: 1661.31, tr: 1650.60, tl: 2083.13} (BR error: 2.22 mm, BL error: 2.36 mm)
Index 14: {bl: 1978.28, br: 1506.41, tr: 1822.36, tl: 2225.65} (BR error: 2.35 mm, BL error: 1.80 mm)
Full Fit:
x1 (B): 2929.5 ± 13.5 mm
x2 (C): 2930.4 ± 13.5 mm, y2 (C): 2307.1 ± 17.2 mm
x3 (E): -3.7 ± 2.2 mm, y3 (E): 2315.5 ± 17.5 mm
Residual sum: 128457.228 mm²
x1 (B): 2901.3 ± 10.6 mm
x2 (C): 2901.2 ± 10.7 mm, y2 (C): 2344.1 ± 13.3 mm
x3 (E): -9.9 ± 1.9 mm, y3 (E): 2344.2 ± 13.0 mm
Residual sum: 67126.566 mm²
lower-right-belt-loosening-and-unwinding-during-cut/24309/9
initial 6 fitness started really low, after restarts got to 1.6
Adaptive Init:
x1: 1871.9 mm, x2: 2798.8 mm, y2: 1851.4 mm, x3: 935.9 mm, y3: 1851.4 mm
Threshold: 1.285 mm
Index 0: {bl: 1860.42, br: 1842.31, tr: 1872.87, tl: 1870.88} (BR error: 0.66 mm, BL error: 1.41 mm)
Full Fit:
x1 (B): 2997.6 ± 42.8 mm
x2 (C): 2990.3 ± 44.9 mm, y2 (C): 2200.0 ± 60.9 mm
x3 (E): -33.0 ± 4.2 mm, y3 (E): 2176.6 ± 61.8 mm
Residual sum: 22429.003 mm²
x1 (B): 2977.8 ± 26.9 mm
x2 (C): 2968.5 ± 28.2 mm, y2 (C): 2229.0 ± 37.5 mm
x3 (E): -29.6 ± 2.8 mm, y3 (E): 2207.8 ± 38.2 mm
Residual sum: 10948.109 mm²
at 16 fitness 0.5
Adaptive Init:
Threshold: 2.552 mm
Index 13: {bl: 2091.48, br: 1670.40, tr: 1649.64, tl: 2054.32} (BR error: 3.17 mm, BL error: 0.59 mm)
Index 14: {bl: 1974.64, br: 1529.08, tr: 1812.29, tl: 2186.27} (BR error: 3.00 mm, BL error: 1.22 mm)
Full Fit:
x1 (B): 2974.5 ± 12.5 mm
x2 (C): 2968.6 ± 12.9 mm, y2 (C): 2228.9 ± 17.3 mm
x3 (E): -21.6 ± 2.1 mm, y3 (E): 2223.0 ± 17.2 mm
Residual sum: 111481.254 mm²
x1 (B): 2956.5 ± 11.6 mm
x2 (C): 2948.7 ± 12.0 mm, y2 (C): 2255.3 ± 15.8 mm
x3 (E): -24.7 ± 2.1 mm, y3 (E): 2243.6 ± 15.4 mm
Residual sum: 79542.132 mm²
so it looks like the people reporting problems have bad error ranges, even if the fitness score is high
Can we get some people who are having good results to check?
Retro-ed back to 1.12, minor disaster, USB cable got caught and ripped out motor connection during run, bent and broke cable. I think port is OK but haven’t got a long enough cable to continue with serial port logging.
haven¢t got a long enough cable to continue with serial port logging.
ouch.
I have found that I can gather logs more reliably with telnet than with serial,
except the early logs.
for this testing, everything is saved in the logs you can download form the UI
(and not all of it is going to the serial logs anyway, so we need the UI logs)
do you need to power reset Maslow after loading index.html.gz file
Results before and after
Maslow-serial - 2025-10-15T075210.623.log (31.2 KB)
Maslow-serial - 2025-10-15T081612.420.log (30.1 KB)
yes you do
what do you mean ‘before and after’? and can you post the results of a run with the Maslow-Classic
for comparison, here are the points
run 1
Maslow-Classic
Fitness: 0.9468315277098294
Maslow_tlX: -163.1
Maslow_tlY: 3992.1
Maslow_trX: 4558.7
Maslow_trY: 3942.3
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 4580.9
Maslow_brY: 0.0
new
x1: 4709.1 ± 2.1 mm
x2: 4773.6 ± 2.2 mm, y2: 3956.5 ± 2.6 mm
x3: 202.1 ± 0.8 mm, y3: 4000.5 ± 2.5 mm
maslow classic run 2
Fitness: 0.8918119710774676
Maslow_tlX: -161.3
Maslow_tlY: 4002.9
Maslow_trX: 4542.0
Maslow_trY: 3963.9
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 4572.6
Maslow_brY: 0.0
new
x1 (B): 4700.0 ± 2.7 mm
x2 (C): 4763.2 ± 2.8 mm, y2 (C): 3967.9 ± 3.3 mm
x3 (E): 193.7 ± 1.0 mm, y3 (E): 4004.4 ± 3.2 mm
that seems like a pretty significant difference between the numbers the two report (200mm difference in width). can you try the new numbers (either by calibrating with the new algorithm or by just entering the numbers manually) and then report if the machine seems any happier/more accurate?
3rd Version, after power reset of Maslow
Maslow-serial - 2025-10-15T090308.631.log (29.0 KB)
Fitness: 0.8528570070092053
Maslow_tlX: -162.7
Maslow_tlY: 4017.9
Maslow_trX: 4526.8
Maslow_trY: 3979.3
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 4557.9
Maslow_brY: 0.0
and
x1: 4692.8 ± 3.0 mm
x2: 4757.2 ± 3.0 mm, y2: 3975.0 ± 3.5 mm
x3: 194.6 ± 1.1 mm, y3: 4012.0 ± 3.5 mm
||. | old1 | old2 | old3 | new1 | new2 | new3|
| | .94 | .89 | .85 | | | |
|brx | 4580.9 | 4572.6 | 4557.9 | 4709.1-+2.1 | 4700.0-+2.7 | 4692.8-+3|
|tlx | 163.1 | -161.3 | -162.7 | 202.1-+.08 | 193.7-+1 | 194.6-+1.1|
|tly | 3992.1 | 4002.9 | 4017.9 | 4000.5-+2.5 | 4004.4-+3.2 | 4012-+3.5|
|trx | 4558.7 | 4542.0 | 4526.8 | 4773.6-+202 | 4763.2 -+2.8 | 4757.2-+3|
|try | 3942.3 | 3963.9 | 3979.3 | 3956.5-+2.6 | 3967.9-+3.3 | 3975-+3.5|
so much for the table builder…
