Hello everyone, since an update of my yaml file two weeks ago, I have had recurring problems concerning the loosening of the lower belts.
Let me explain: I do everything, retract, extend, tension. So far, so good. But as soon as I try to make my Z HOME, the whole thing loosens slightly and the lower belts are very loose. I tried to avoid this problem by still launching a GCODE file. During jogging, the lower left belt loosens completely. Basically, everything seems to go wrong during movements.
Unfortunately I was stupid in not keeping my original yaml file. However, I tried to reinstall numerous versions of FC and yaml, and finally version 0.83 worked.
I saved this version as well as my calibration values.
Until this morning, it started with wifi disconnections, then these first signs of loose belts during the Z HOME calibration reappeared. I then tried to reinstall a recent version, my saved version (0.83), nothing worked.
< Other problems :
I systematically lose my initial calibration, forcing me to repeat everything : retract, extend, tend.
Also, after a stop, the movements of the maslow are random, if I want to go down, for example it will go up. >
I don’t know what to do anymore, I browsed the forum for days the first time, to no avail.
PS : I use a sturdy wooden frame, an anti-static vacuum cleaner hose, I glued my motor connections before even using the Maslow for the first time.
