I was once able to calibrate but then I think I stupidly overwrote my YAML file because I thought I’d be able to easily calibrate again. Not the case! My bottom right (BR) belt isn’t behaving. It doesn’t behave the same way as the other three belts do during Retract All and Extend All. I was only able to get it to retract all the way just now by increasing the retraction force from 1300 to 1500. Calibration still fails:
Serial Messages
Index.html Version: 0.87
[MSG:INFO: FluidNC v0.87 (Maslow-Main-ec171155-dirty)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:<SSID redacted>]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting..]
[MSG:INFO: Connected - IP is 192.168.68.123]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
[MSG:INFO: Bottom Left pulled tight with offset -1517.438]
[MSG:INFO: Top Left pulled tight with offset -1532.866]
[MSG:INFO: Bottom Right pulled tight with offset -1509.762]
[MSG:INFO: Top Right pulled tight with offset -1530.407]
[MSG:INFO: Center point deviation: TL: -0.019 TR: 0.245 BL: -13.090 BR: 185.307]
[MSG:ERR: Center point deviation over 100.000mmm, your coordinate system is not accurate, adjust your frame dimensions and restart.]
Anyone see anything amiss? I’m using a vertical frame, roughly 71" high by 111.5" wide. Thank you in advance for any help.
