I completely agree and currently run a dedicated wireless network for a several machines like 3d printers in my garage. The hope was to not pick up a new tablet or raspberry pi and instead keep things simple. But oh well, I suppose you really cant have too much pi in your life.
Welcome, @gmihovics! Weāre glad youāre here and contributing to the discussion. Threads here wander off into new territory all the time, so no sweat.
I have looked at a few fans for a standard connector and Iām not sure there is one. The ones I use are 12v and have mini JST connectors. I soldered pins at a right angle coming off the shields 12v in. Itās pretty ghetto
I keep thinking about how to make these boards plug and play compatible with the firmware. It would be really nice to not have to maintain two branches of the firmware.
Would it be possible to set the pins which are currently used to detect the board version to be high using input_pullup and then if we detect board version 1111 (all high) check the pins that this version uses to indicate board version number?
Using pullups will work. Are you amenable to having the version pins as #defines in config.h as the TLE5206 branch does?
I think we can ignore pins 52 & 53 for a start, theyāre always low on versions 1-3 and not used on the TLE5206 board.
Iāve opened a PR with what Iām talking about.
The existing version detection setup uses two of the pins that would be useful for SPI, and arenāt needed to identify any of the boards in present circulation. At the same time, adding a couple more version detection pins so that the routine will be ready to accommodate future versions makes sense.
Ok, if those pins arenāt used on any existing board, define different pins to
use instead, but donāt force those two pins to be pulled high or it will cause
problems with other uses
Iām getting way to far behind in my forum readingā¦
Count me in for a group buy, too, if itās not too late. More than willing to contribute to the effort even if the maslow is still collecting dust in the otherwise empty shop. Soon as the post-snowmelt mud firms up a bitā¦
So just how fast will the current motors spin at 40V, or rather how much can they be juiced up before the magic smoke departs? Will the current limiting allow the extra voltage to help with getting the motors up to speed quicker, like the equivalent use to overcome stepper motor inductance?
one more thought on this. Can we get LEDs on the input pins to the board and
some easy way to put some on the output of the MOSFETs so that it can be a
simple āare the LEDs blinking togetherā diagnostics to find blown MOSFETS (and
other simple diagnosis, like loose power cords )
Iāve been looking at a daughter board that could be plugged into a motor circuit at either the motor or board end. It would make measuring voltage easy, and could allow a current measurement as well. LEDs on that would resolve between a bad drive, a bad cable and motor and a bad motor. A red/green LED across the M+ and M- would give the info youāre describing. A final plus is that a quadrature encoder divider would fit there nicely.
On the TLE5206 board itself, the chips have thermal and over-current shutdown. Iāve driven the output directly into an ammeter to see what high current would do - the output drops, but is normal again when the meter is removed. The āblown chipā issue should be much rarer on these boards.
Lights would be nice. It would also help with the aux pins for router shutoff and auto zeroing the z-axis. Just one more level of confirmation that everything is working together.
