Hello!
I started my Maslow build back in September, and have been hacking it together from locally sourced bits here in the UK. I sourced a couple of motors from Alibaba but have failed to get them working. Fortunately, Hannah and Bar have now made available the Maslow motors, so I’m looking forward to some cutting action in the new year. I ground to a halt in October, the electronics ground me down and life got in the way. But now I have motors on their way I’ve got a new burst of enthusiam and decided to get prepared by developing my sled and frame.
I have a Trend T11e and a Katsu (makita copy, probably same factory, different label) laminate trimmer. I aim to make sleds for both, but started with the big one:
The Tend is a beast and quite heavy, so my reckoning is that it’s own weight will likely be adequate, maybe with a little balancing/tuning. I’ve made the sled out of 7mm ply and attached a sheet of polycarb to reduce friction. The base seems to be small enough not to flex or warp, and being thin allows me to stick another larger layer under the current one if I experience sled instability issues, which is likely given the weight of ‘The Beast’!
I had a couple of stainless bars that I bent into rings. This was really difficult and made my hands ache for a while. I cut a ply disc around which to shape the bar and just kept working it until I was happy it was circular. I made two and one still requires a some fettling.
I made ply mounts and glued and screwed those to the sled, made captive nuts to pinch the ring. This enables me to adjust the ring height (a little).
For the chain carrier pulleys I used a pair of V-bearing rollers in each block. The blocks were whittled out of ply triangles. The blocks are lovingly encased in hotglue for the full-on ‘homemade’ effect, and to keep everything in place. I ended up cutting shims from credit cards to mitigate some sloppiness in the blocks caused by over-zealous whittling!
It’s all a bit rough around the edges, but seems to move freely and is pretty sturdy. The test will be when I come to hang it with The Beast attached.
It’s a start, but will be revised once I’ve got the thing moving. I’m interested in your thoughts, and would value any feedback.
Cheers,
Miles
