Tried to fix z stop and had to tell it to go below what it thought was bottom z home and it freaked out and wants me to reset belts why?
Maslow-serial (44).log (4.0 KB)
i cant get it to move up or down even after restart, im gonna have to keep it propped up i guess and retract and re extend the belts and see if that fixes it
From your Serial Log
Release Tension
[MSG:INFO: Requesting state change from Ready To Cut to Releasing Tension]
[MSG:INFO: TL: 1994.755 TR: 1999.382 BL: 1992.543 BR: 2003.644]
[MSG:INFO: Succeeded] Here you had “Ready To Cut”
JogTo: $J=G91G20F98.43Y-12 (inch) Was the Jog successful?
[MSG:INFO: Zm=39.150mm, Z home=35.970mm, Z position=3.180mm] Here the Maslow thinks the Z access is 3.18 above Maslow Home
[MSG:INFO: Requesting state change from Releasing Tension to Belts Extended]
JogTo: $J=G91G21F300Z-10.01 (mm)Sent it down 10.01mm to 29.140
JogTo: $J=G91G21F300Z-10.01 (mm)Sent it down 10.01mm to 19.13
JogTo: $J=G91G21F300Z-10.01 (mm)Sent it down 10.01mm to 9.12
JogTo: $J=G91G21F300Z-10.01 (mm)Sent it down 10.01mm to -0.89, This should have asked are you sure?
JogTo: $J=G91G21F300Z-10.01 (mm)Sent it down 10.01mm to -10.9, This should have asked are you sure?
The last two jogs have lowered the Z axis as far as it will go, but the Maslow maths thinks it is at -10.9. Therefore the belts will not be accurately reflecting the real world. If you bottom out you have to reset the Zm to zero (setup, config., Set Z axis) before trying to move.
So now its lost, the only alternative is a retract, extend sequence, but before that reset the Z axis to Zero.
Maslow is not ready to move.
Could not perform Jog. Belt lengths are unknown.
i was trying to bottom it out to reset it
Are you in inches mode?
i may have been, i caught myself a little later after i fixed it in inches instead of mm when i was trying to lower it again so it is definitely possible and quite likely, i also just ended up letting it run the whole distance down it wanted to until it stopped so it could then be told a new z stop, i was quite tired when i was trying to mess with it so i imagine i just wasn’t paying attention to the right stuff most likely
Have you got control of it now? It should not matter, but I have noticed an occasional overrun when in inches mode.
more or less, i will download those updates you sent and try again and see if it tries to top out again in my process of cutting some more stuff out
