Few questions about Maslow behavior
Hi there, I have a pristine Maslow 4.1.
Today I’ve made my first cut. It was (almost) successful ! I’m really happy. :partying_face:
But I’ve struggled to make things work perfectly.
Every time I start the Maslow, I have a set the Z stop and the Z Home. Even if the bit is the same and stays on the router. Is this normal ?
For some reason, Carbide Create didn’t generate the tabs on my gCode. I had to pause the Maslow, stop it (still turned on) and upload the new GCode and start again. It didn’t work. The Maslow refused to start and I had to turn it completely off, release tension, retract belts, expand belts and apply tension before being able to start it again.
Why isn’t it possible to restart it after a stop ? Or maybe there is a function I don’t understand (most likely). It’s really anoying not being able to turn it off, leave it with tension and turn it on later.
Despite the 4 restarts I had to make, the Maslow has successfully been able to be reliable and precise except on the bottom left corner where the first pass was 1cm off:
Thanks for your help.
Have a nice day
Edit:
I have a serious issue with Z:
I’ve defined the Z stop to the lower position of the router (without a bit).
With my bit, I’ve defined Z home to 27mm.
In my GCode, safe height is set to 8mm.
When I run the Gcode, the router goes down to Z = 8mm not 27+8mm. So the router is going 19mm inside my material to move.
Here are the logs (v1.24):
READY_TO_CUT:]
[MSG:INFO: TL: 2022.936 TR: 2022.753 BL: 2017.772 BR: 2027.703]
[MSG:INFO: Succeeded]
[MSG:WARN: Position error on Top Left axis exceeded 15mm while running. Error is -182.325mm Counter: 1]
[MSG:WARN: Previous error was -182.325mm]
[MSG:WARN: Position error on Bottom Left axis exceeded 15mm while running. Error is -172.395mm Counter: 1]
[MSG:WARN: Previous error was -172.395mm]
JogTo: $J=G91G21F300Z8 (mm)
JogTo: $J=G91G21F2500X-20 (mm)
[MSG:WARN: Low memory: 9936 bytes]
Stop Maslow and Gcode
[MSG:INFO: Reset during file job at line: 32 (0.306% complete) - Last motion command: G1]
[MSG:INFO: Raising Z from work Z -11.820mm to 2.000mm (Z home + 2.000mm)]
JogTo: $J=G91G21F300Z1 (mm)
[MSG:INFO: Zm=29.000mm, Z home=27.000mm, Z position=2.000mm]
During an “Extend All”, when the Bottom Left belt is pulled with moderate force, the belt can skip one or more teeth as it passes over the two small plastic rollers, one of which contains the encoder magnet. The rollers do turn, but the belt appears to slip over them and jump teeth. The gap between the belt and the rollers seems similar on all four arms when I push the belt to one side.
No this is not normal, does your location use commas to distinguish the decimal point?
Can you put the GCode up here, from what you have said it looks like the Z parameters are set correctly, so I suspect GCode might be a problem.
This is a problem, maybe one of the rollers is binding or the bearing is not seated correctly. If you pull that arm apart, also check the spool can turn easily on both halves before reassembly, it may require sanding.
Also the Z value should be 35.000 not 35,000.
Pause stops the Maslow from moving and is useful if you need to move away from the machine for some reason. Try to ensure the bit is not in the material if you use pause (risk of fire if bit is in contact with material and still spinning). On Play the Maslow will continue the current job.
Stop will halt the job, there is a delay while the buffer is emptied, then the bit is raised out of the material (2mm above Home Z by default, setting is Park Z). Pressing Play will start the job again from the beginning (or a new one if another GCode is loaded.
Thanks for your answer.
The comma is automatically set when I try to move along the Z axis.
My Gcode is available here: G21G90G17G94G54G0 Z8M3 S18200(Toolpath: Exterieur)(Offset: outsi - Pastebin.com
About the rollers, I’ve disassembled the arm, sanded the spool (and cut extra belt length because last 30 cm were touching the arm). I’ve also added some lubricant around the spool, the gears and the rollers heads (not on the roller teeth).
It would be really awesome if when pressing Pause and turning off the maslow, we could resume the operation later.
I’m currently assembling my maslow after the changes. I will let you know how it’s going on.
I can’t open that file, could you just copy/paste the 1st 20 lines or so.
Unfortunately, that is not possible. I spent a considerable amount of time trying to get that to work.
You can manually edit the file to restart where you have stopped, but you need to ensure the setup components are retained in the modified file.
To hopefully fix this I have put together a modified version of the software which should convert commas to periods prior to storing result, but I can’t test it as I can’t enter commas in number fields.
Please try loading the following using the 1st Green button under the FluidNC pulldown for the index.html.gz and the Orange button to load firmware.bin. The Maslow will then restart.
firmware.bin (1.9 MB)
index.html.gz (140.6 KB)
You can then try entering a number and see if it stores properly.
I think that @ian_ab is right that this might be causing some issues. Someone else reported the same thing (it is browser and location dependent) and it should be fixed in the latest firmware version.
Here are the first lines of the Gcode file:
G21
G90
G17
G94
G54
G0 Z8
M3 S18200
(Offset: outside, start 0mm, end 16mm, stepdown 3mm)
G0 X-1.031 Y-0.046
G1 Z-3 F400
G1 F2000
G1 X-1.016 Y-0.453
G1 X-0.97 Y-1.671
G1 X-0.922 Y-2.971
G1 X-0.905 Y-3.195
G1 X-0.632 Y-5.618
G1 X-0.632
G1 X-0.486 Y-6.91
G1 X-0.453 Y-7.132
I’ve updated my firmware to 1.26 and it still displays a comma. I’ve used a brand new yaml file to avoid any issue and started a new “Find anchors” calibration. Default grid was 9x9 and everything went great until waypoint 77 where the bottom left belt didn’t retract at all which made the calibration failed.
Surprinsingly, when I applied tension, the belt is correctly pulled.
I’ve changed grid size to 3x3. Everything went smoothly until waypoint 7 and then the Maslow stopped completely. Calibration was stuck and the maslow relased tension automatically.
Here are the full logs:
Serial Messages
Index.html Version: v1.26.0
[MSG:INFO: FluidNC v1.26.0]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 5]
[MSG:INFO: Axis A (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis B (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis C (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Axis D (-4000.000,0.000)]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: tmc_2209 UART1 Addr:0 Step:gpio.15 Dir:gpio.16 Disable:NO_PIN R:0.11]
[MSG:INFO: Motor1]
[MSG:INFO: tmc_2209 UART1 Addr:1 Step:gpio.46 Dir:NO_PIN Disable:NO_PIN R:0.11]
[MSG:INFO: STA SSID is not set]
[MSG:INFO: AP SSID maslow IP 192.168.0.1 mask 255.255.255.0 channel 1]
[MSG:INFO: AP started]
[MSG:INFO: WiFi on]
[MSG:INFO: WebSocket send protection active (canSend() checks enabled)]
[MSG:INFO: Captive Portal Started]
Grbl 1.26 [FluidNC v1.26.0 (wifi) '$' for help]
[MSG:INFO: '$H'|'$X' to unlock]
[MSG:INFO: Current z-axis position loaded as: 0.000]
[MSG:INFO: BR encoder angle difference too large (-1466 counts), treating belt positions as stale]
[MSG:INFO: Starting Maslow Version v1.26.0-dirty]
[MSG:INFO: Maslow_Retract_Current_Threshold: 1300]
[MSG:INFO: Maslow update loop registered with hardware watchdog]
[MSG:INFO: Zm=0.000mm, Z home=0.000mm, Z position=0.000mm]
Retract All
[MSG:INFO: Bottom Right pulled tight with offset -1908.729]
[MSG:INFO: Top Right pulled tight with offset -439.843]
[MSG:INFO: Bottom Left pulled tight with offset 526.900]
[MSG:INFO: Top Left pulled tight with offset 527.640]
Extend All
[MSG:INFO: All belts extended to 2200.000mm]
Apply Tension
[MSG:INFO: Requesting state change from Belts Extended to Taking Slack]
[MSG:INFO: Waypoint 0 coordinates: X=0.000 Y=1.607]
[MSG:INFO: Center point deviation: TL: 0.000 TR: 0.000 BL: 2.044 BR: 6.201]
[MSG:INFO: Center point deviation within 12.000mm, your coordinate system is accurate]
[MSG:INFO: Requesting state change from Taking Slack to Ready To Cut]
[MSG:INFO: Synchronizing motor positions for READY_TO_CUT:]
[MSG:INFO: TL: 2032.845 TR: 2030.612 BL: 2007.165 BR: 2012.222]
Find Anchors
[MSG:INFO: Requesting state change from Ready To Cut to Finding Anchor]
[MSG:INFO: Grid width constrained to work area: 0.000 mm (work area X: 200.000 mm)]
[MSG:INFO: Grid height constrained to work area: -100.000 mm (work area Y: 100.000 mm)]
[G92:0.000,0.000,0.000,0.000,0.000]
[G54:0.000,0.000,0.000,0.000,0.000]
[MSG:INFO: Machine Position found as X: 8.820 Y: -32.930]
[MSG:INFO: Setting motor positions from hardware readings:]
[MSG:INFO: TL: 2032.899 TR: 2030.633 BL: 2007.165 BR: 2012.232]
[MSG:INFO: Detected HORIZONTAL orientation (extension <= 35.000 mm)]
[MSG:INFO: Orientation set to: HORIZONTAL (Maslow_vertical=false)]
[MSG:INFO: Center point off by: TL: 0.000 TR: 0.000 BL: 3.558 BR: 6.614]
[MSG:INFO: Machine Position computed as X: 8.107 Y: -34.916]
[MSG:INFO: Waypoint 1 coordinates: X=158.107 Y=-34.916]
[MSG:INFO: Waypoint 2 coordinates: X=158.107 Y=115.084]
[MSG:INFO: Waypoint 3 coordinates: X=8.107 Y=115.084]
[MSG:INFO: Waypoint 4 coordinates: X=-141.893 Y=115.084]
[MSG:INFO: Waypoint 5 coordinates: X=-141.893 Y=-34.916]
[MSG:INFO: CLBM:[{bl:2159.99, br:2163.79, tr:2185.05, tl:2184.49},{bl:2268.73, br:2050.89, tr:2079.33, tl:2299.27},{bl:2375.92, br:2159.74, tr:1968.46, tl:2207.4},{bl:2268.15, br:2256.98, tr:2079.63, tl:2098.65},{bl:2162.3, br:2367.37, tr:2198.31, tl:1981.75},{bl:2041.59, br:2267.06, tr:2303.52, tl:2087.06}]]
[MSG:INFO: Find Anchors fit: rms=0.284mm max=0.601mm perAnchor=[0.149,0.366,0.375,0.159]mm converged=1]
[MSG:INFO: Find Anchors recompute complete: tl=(-1.640,2609.250) tr=(3468.811,2614.360) brX=3476.945 SSR=1.935 points=6]
[MSG:INFO: Waypoint 6 coordinates: X=0.000 Y=0.000]
[MSG:INFO: Waypoint 7 coordinates: X=0.000 Y=50.000]
Did I do something wrong ?
Please load the modified versions above. It may still display numbers with a comma but it should save internally as a period. Let me know if this works please. They will still be V1.26.0 but will also have
[MSG:INFO: FluidNC v1.26.0 (HEAD-d12725a9-dirty)] appended as they are not release versions yet.
This should be setting the Z depth to Z home + 8mm. Can you confirm that Z home is above zero. When you reset Z Stop it also sets Z home to zero, so you have set Z stop first then set Z home.
The later versions of Find Anchors expects the Grid size to be 0 x 0. There is no reason to change this.
You can reduce the work area dimensions which will restrict the size of the work area (by default it is 2400 x 1200). This is useful to prevent the Maslow getting too close to the edges. I run mine at 2200 x 1000 unless I have a larger cut requirement.
When you are running Find Anchors, there is no need to Apply Tension, just go straight to find Anchors after extending belts.
This is an extremely small work area. Suggest you expand it.
Hello Ian,
I’ve updated my firmware to v1.26.0-6-gd12725a9-dirty.
Z Home
Then, I’ve defined Z Stop (Lower position on the Z axis) and Z Home (bit touching the workpiece):
Setup → Set Z -Stop
Set Z-Stop
Move Z up to 27mm
Define Z-Home > Define Z Home
Z Home pos set: Z=27mm
[G54:0.000,0.000,27.000,0.000,0.000]
The Test button confirms it has been correctly set up:
// Setup > Test
Test
Index.html Version: v1.26.0-6-gd12725a9-dirty
[MSG:INFO: Firmware Version: v1.26.0-6-gd12725a9-dirty]
[MSG:INFO: I2C Timeout: ]
[MSG:INFO: 10]
[MSG:INFO: All tests passed on Top Left]
[MSG:INFO: All tests passed on Top Right]
[MSG:INFO: All tests passed on Bottom Left]
[MSG:INFO: All tests passed on Bottom Right]
[MSG:INFO: Zm=27.000mm, Z home=27.000mm, Z position=0.000mm]
I’ve restarted the Maslow immediately and the position is kept.
I’ve also changed the workpiece dimensions to 1000x2000 (I had forgotten a zero, my bad).
The Maslow keeps saying [MSG:WARN: Low memory: 5264 bytes].
Then I’ve retracted the belts
Retract All
[MSG:INFO: Top Right pulled tight with offset -3830.856]
[MSG:INFO: Bottom Right pulled tight with offset -4005.119]
[MSG:INFO: Bottom Left pulled tight with offset -3967.479]
[MSG:INFO: Top Left pulled tight with offset -4010.863]
And finally extended them all and attached to the anchors:
Extend All
[MSG:INFO: All belts extended to 2300.000mm]
Before starting a new calibration, I’ve move the maslow down.
In the “Set Z Home Position” dialog, Z=0 and Z Home=27mm
But after running Setup > Test, it gives a different Z position:
Test
[MSG:INFO: 10]
There are literaly two different Z values !
After a reboot, surprise:
[MSG:INFO: Zm=29.000mm, Z home=0.000mm, Z position=29.000mm]
What the hell ?!? Physically, the router is at the lower position. Z should have been 0 (or even 2)mm but certainly not 29mm !
Calibration time
As you told me in your previous message, I’ve tried to run a new calibration without applying tension first.
Find Anchors
[MSG:INFO: Requesting state change from Belts Extended to Finding Anchor]
[MSG:INFO: Machine Position found as X: 11.479 Y: -450.534]
[MSG:INFO: TL: 2312.415 TR: 2309.451 BL: 2305.232 BR: 2310.021]
But the Maslow stays stuck indefinitely without any tension (Red led is blinking) and no additional log messages.
I had to restart it, retract belts, extend belts and apply tension before running a new calibration.
Apply Tension
During calibration, the Maslow has measured a total of 86 waypoints.
Around waypoint 29 or 30, then waypoints 52 or 53 and then to the last 10 points before failure, the bottom left belt became completely loose.
Retractation force is set to 1300 and it never fails during “Retract All” task. During “Extend All”, the belts went smoothly.
Find Anchors
[MSG:INFO: Machine Position found as X: 6.235 Y: -29.756]
[MSG:INFO: TL: 2028.916 TR: 2030.698 BL: 2007.315 BR: 2015.764]
[MSG:INFO: Center point off by: TL: 0.000 TR: 0.000 BL: 2.758 BR: 6.030]
[MSG:INFO: Machine Position computed as X: 6.363 Y: -31.758]
[MSG:INFO: Measured waypoint 86]
[MSG:INFO: Waypoint 86 coordinates: X=859.930 Y=-262.537]
[MSG:INFO: CLBM:[{bl:2159.69, br:2166.47, tr:2184.46, tl:2181.18},{bl:2269.84, br:2058.46, tr:2077.83, tl:2289.4},{bl:2374.65, br:2157.71, tr:1969.32, tl:2207.38},{bl:2265.89, br:2251.34, tr:2081.81, tl:2101.41},{bl:2161.71, br:2357.89, tr:2197.89, tl:1989.46},{bl:2044.35, br:2276.05, tr:2301, tl:2075.2},{bl:2139.79, br:2182.95, tr:2204.9, tl:2162.81},{bl:2140.67, br:2143.96, tr:2205, tl:2203.2},{bl:1986.17, br:2293.91, tr:2359.79, tl:2065.8},{bl:1998.42, br:2330.55, tr:2350.71, tl:2026.86},{bl:2040.19, br:2364.56, tr:2315.22, tl:1986.55},{bl:2180.35, br:2242.38, tr:2165.68, tl:2104.44},{bl:2326.47, br:2101.71, tr:2017.76, tl:2253.21},{bl:2355.16, br:2060.06, tr:1994.07, tl:2297.1},{bl:2319.54, br:2018.19, tr:2033.16, tl:2332.06},{bl:2280.96, br:1978.1, tr:2079.03, tl:2368.07},{bl:2125.13, br:2080.89, tr:2225.31, tl:2269.82},{bl:1971.17, br:2237.59, tr:2373.25, tl:2127.55},{bl:1822.06, br:2398.55, tr:2527.11, tl:1991.85},{bl:1791.88, br:2442.93, tr:2563.4, tl:1954.05},{bl:1834.21, br:2471.16, tr:2527.27, tl:1912.93},{bl:1877.92, br:2502.2, tr:2493.36, tl:1871.32},{bl:1921.81, br:2530.15, tr:2460.5, tl:1833.49},{bl:2056.58, br:2454.48, tr:2317.02, tl:1894.58},{bl:2183.87, br:2311.09, tr:2169.97, tl:2036.91},{bl:2323.3, br:2170.6, tr:2020.65, tl:2188.3},{bl:2470.29, br:2032.58, tr:1875.95, tl:2345.1},{bl:2514.81, br:1994.22, tr:1835.73, tl:2391.78},{bl:2532.72, br:1954.41, tr:1823.47, tl:2429.45},{bl:2498.53, br:1915.46, tr:1866.12, tl:2459.34},{bl:2465.89, br:1877.09, tr:1907.11, tl:2487.42},{bl:2439.96, br:1835.51, tr:1945.07, tl:2522.93},{bl:2299.54, br:1866.23, tr:2083.17, tl:2482.49},{bl:2145.28, br:2012.87, tr:2214.69, tl:2340.42},{bl:1989.98, br:2169.52, tr:2356.37, tl:2196.04},{bl:1837.51, br:2332.15, tr:2508.13, tl:2057.9},{bl:1692.59, br:2497, tr:2661.11, tl:1925.26},{bl:1655.16, br:2544.46, tr:2704.16, tl:1892.43},{bl:1641.06, br:2586, tr:2736.92, tl:1857.55},{bl:1667.18, br:2616.5, tr:2715.34, tl:1815.85},{bl:1708.11, br:2642.01, tr:2684.11, tl:1774.5},{bl:1750.57, br:2662.56, tr:2654.46, tl:1739.02},{bl:1794.72, br:2690.87, tr:2625.68, tl:1696.58},{bl:1939.07, br:2669.35, tr:2489.74, tl:1689.85},{bl:2051.83, br:2522.69, tr:2340.43, tl:1824.34},{bl:2174.87, br:2374.83, tr:2189, tl:1972.84},{bl:2311.18, br:2230.68, tr:2036.41, tl:2126.41},{bl:2454.22, br:2092.59, tr:1889.26, tl:2285.84},{bl:2601.35, br:1962.23, tr:1750.01, tl:2442.06},{bl:2644.88, br:1924.87, tr:1711.84, tl:2491.99},{bl:2684.09, br:1891.18, tr:1677.57, tl:2535.79},{bl:2702.99, br:1851.04, tr:1684.05, tl:2574.64},{bl:2702.88, br:1809.31, tr:1699.34, tl:2606.49},{bl:2702.83, br:1768.23, tr:1721.14, tl:2639.15},{bl:2675.11, br:1727.84, tr:1747.16, tl:2670.7},{bl:2639, br:1685.23, tr:1787.35, tl:2701.26},{bl:2506.7, br:1672.01, tr:1932.21, tl:2688.38},{bl:2356.29, br:1802.05, tr:2042.38, tl:2546.47},{bl:2201.53, br:1946.76, tr:2167.48, tl:2402.4},{bl:2042.85, br:2104.44, tr:2307.32, tl:2254.67},{bl:1894.65, br:2261.11, tr:2450.21, tl:2119.16},{bl:1746.31, br:2425.34, tr:2602.74, tl:1985.72},{bl:1614.5, br:2584.98, tr:2749.06, tl:1862.51},{bl:1579.72, br:2633.8, tr:2790.79, tl:1833.28},{bl:1543.43, br:2681.97, tr:2834.96, tl:1800.54},{bl:1521.31, br:2727.44, tr:2875.42, tl:1770.47},{bl:1539.93, br:2758.82, tr:2881.2, tl:1729.26},{bl:1554.82, br:2789.88, tr:2881.04, tl:1688.18},{bl:1592, br:2816.47, tr:2847.82, tl:1646.35},{bl:1635.98, br:2839.3, tr:2821.05, tl:1604.24},{bl:1680.03, br:2862.57, tr:2795.42, tl:1563.02},{bl:1851.25, br:2896.82, tr:2669.71, tl:1481.42},{bl:1942.17, br:2755.15, tr:2525.03, tl:1600.1},{bl:2039.19, br:2611.99, tr:2380.34, tl:1735.7},{bl:2145.97, br:2473.75, tr:2238.67, tl:1873.43},{bl:2271.8, br:2328.46, tr:2087.85, tl:2026.4},{bl:2403.88, br:2191.82, tr:1942.11, tl:2181.98},{bl:2547.94, br:2056.62, tr:1796.2, tl:2342.69},{bl:2693.66, br:1930.21, tr:1658.93, tl:2501.66},{bl:2736.65, br:1893.66, tr:1622.89, tl:2553.1},{bl:2780.71, br:1857.17, tr:1585.96, tl:2602.25},{bl:2823.09, br:1823.42, tr:1551.1, tl:2649.27},{bl:2842.95, br:1785.53, tr:1563.63, tl:2685.75},{bl:2842.95, br:1743.65, tr:1585.38, tl:2716.31},{bl:2842.94, br:1701.44, tr:1614.91, tl:2743.8},{bl:2842.95, br:1659.96, tr:1642.13, tl:2773.58},{bl:2842.95, br:1618.51, tr:1668.42, tl:2804.7}]]
[MSG:ERR: Find Anchors fit failed: maxResidual=25.611mm at anchor=2 measurement=86 (limit 15.000mm)]
[MSG:ERR: Find Anchors recompute failed]
[MSG:INFO: Find Anchors state reset]
[MSG:INFO: Requesting state change from Finding Anchor to Belts Extended]
And it fails dramatically…
Here is a video of the “incident”: https://youtu.be/N4stzFT4JUI
I’m on the verge to give up on Maslow !
Don’t give up you a nearly there. We just have to figure out why that belt is not retracting.
Thanks for testing the new versions of software. The initial result looks good but after restarting looks weird. Z home has been set to 0.
Did you use the SET Z-STOP under the Set up menu to reset Z-Stop? This sets both Zm and Z home to Zero at the current position. It is also set when you run find Anchors.
This is OK, it is saying the Zm (machine height is 29mm above Zero, the position when the Maslow is fully down) Z home is 27mm as per your setting and the Z position is 2mm above Z home. Which will happen if you pressed Park or Stop.
Find Anchors, what is going on?
I think the bottom left belt is binding for some reason when at extreme extension for that belt. Maslow doesn’t see it as a failure until it attempts to pull to the 2nd last position. Did the belt retract after the failure?
One thing I would change, try dropping the Retract force to 900 and then Retract and Extend. If it still reliably retracts drop in increments of 100 until one or more belts don’t retract, then increase Retract force by 100. The Find Anchors appears to more accurate when the Retract force is at it’s lowest reliable value.
If you have a look in your maslow.yaml file you should have anchor positions which are pretty close to being accurate for your set up. Save a copy of this file and use it as the starting point for any future Find Anchors, unless you change the physical layout of your setup.
Yes, I’ve use this button then the Set Z Home one.
After new start today:
That’s what I thunk but the belt retracts perfectly after the failure (after hitting Retract All).
Retractation force Retract all
1300 (Previous value) OK
900 OK
800 OK
700 All but one
I’ve double checked with a force of 800.
Final retractation force applied: 900
In the browser console, I have seen two different values:
$/Maslow_Retract_Current_Threshold=800
Which one is correct ? The UI displays 800.
I don’t have enough time today to try a new calibration but will do tomorrow.
When you reload it should match. If you press Test it should display correct value. You could also try reducing the Width by 100 to see if that makes any difference before running Find Anchors.
Which belt did not retract at 700?
It was top right belt
Sorry to see you are giving up. Good luck with your next project.
