"Hooking" on horizontal cuts at the top of the build area
Example
Causes and Solutions:
- Sled is too heavy: Reduce the weight on the sled
- Power supply is insufficient to keep up: Try lowering the feed rate. Also check the voltage of the power supply when this situation occurs. If voltage drops, then consider upgrading power supply.
