Tonight, I installed 0.73 and tried to run a calibration afterwards. I had been having some issues with the belts being less than taut and I figured this update was likely to help because I wasn’t turning the machine on with the z axis zeroed out.
After the update, I am unable to get through a calibration and the machine moves very differently than it did before when calibrating. The new way of moving might be intended, but I mention it because of the issues calibrating. I have tried to run it 4 or 5 times. Most runs, it gets a few points in and does an emergency stop. Once, it go through 9 points and failed the fitness check.
One thing I have noticed is that a lot more belt is getting unwound on the spools in the process. I’ll try to upload a video.
Has anyone else run into this? Any ideas?
This is what it looks like https://youtu.be/aO8N6Ako9hQ
CalibrationLog.txt (3.3 KB)
