Hello, I seem to be having trouble setting things up…
The calibration seems to work and asks for a restart. It never does very many waypoints though, certainly not 3x3 then 5x5 then 9x9, regardless how I fill in the settings in “Config” or even leave them blank.
After restart after calibration I learned from the forum that you have to retract all belts again (so first get them of the frame) and then extend and this time instead of “calibrate” use “apply tension” So far every thing seems to work as planned.
Then I tried moving around with the x and y in the which sort of works, it does not always get the direction right away and the tension in the belts gets lost very quickly. Is this normal? After one calibration moving around even made the tension go very high and I had to stop the whole thing for fear of it tearing itself apart. I think that time I had only calibrated a 1000x1000 square and tried how far to the left it would let me go with the x/y moves and what would happen. It didn’t look good to me and I did the whole calibration process again. I tried 2000x1000 area, I tried 3x3, and 5x5 and 9x9 settings in the Config before calibrating. Nothing seems to work properly and each time I have to retract and extend all belts twice to get thru the calibration and the restart with applying tension which is and enormous hassle. I must be doing something wrong…
Can somebody help me? Does this sound familiar to anybody? And what is the solution? Or is this all normal and I should try a g-code…
I am using the latest firmware (v0.71).
That does not sound normal; after a “good” calibration, it should move around with all the belts snug if not tight. If you can try another calibration of at least 1000x1000 and when its done copy the text in the serial output text area and post it, that may help us see what might be happening.
Ok thank you, I will.
what firmware version are you running? the calibration has changed significantly
over time.
The current full release is 0.71 (0.72 will be released 5/8)
@dlang I am running 0.71. in all my attempts. Maybe my “frame” which is my shed wasn’t stable enough or square enough.
I made new anchor point measurements and it turned out not to be as square as I hoped, so I improved that. It is now square almost to the mm.
I have tried again as @ronlawrence3 asked me to.
Here is what was in the dialog:
The errors in the beginning might have been from waiting too long. I repaired the non squareness after I restarted the Maslow to do the calibration but before the actual calibration. So this time it was calibrated mith better (squarer) anchor points. I just let the Maslow sit there while I was doing it.
Serial Messages
[MSG:INFO: Caution: Unlocked]
error:3
error:3
error:3
error:3
error:82
error:3
error:3
error:3
error:3
error:82
[MSG:INFO: Top Right pulled tight with offset 0.000]
[MSG:INFO: Top Left pulled tight with offset 0.000]
[MSG:INFO: Bottom Right pulled tight with offset -0.011]
[MSG:INFO: Bottom Left pulled tight with offset -15.557]
[MSG:INFO: Center point deviation: TL: -0.029 TR: 0.159 BL: -4.953 BR: -2.636]
CLBM:[{bl:2041.46, br:2045.74, tr:2047.49, tl:2050.07},{bl:1966.57, br:1968.63, tr:2128.69, tl:2131.68},{bl:1870.30, br:2064.78, tr:2220.41, tl:2045.87},{bl:1950.62, br:2140.56, tr:2143.11, tl:1958.06},{bl:2038.41, br:2220.38, tr:2066.91, tl:1874.39},{bl:2126.67, br:2132.56, tr:1967.67, tl:1968.96},{bl:2218.95, br:2044.10, tr:1871.40, tl:2068.55},{bl:2142.09, br:1956.14, tr:1953.66, tl:2144.46},{bl:2065.89, br:1872.42, tr:2041.29, tl:2224.31},]
Computing… This may take several minutesFitness: 1.4216445 in 100
Fitness: 1.4427431 in 200
Fitness: 1.4537745 in 300
Fitness: 1.4659507 in 400
Fitness: 1.4763466 in 500
Fitness: 1.4858971 in 600
Fitness: 1.4936371 in 700
Fitness: 1.5002636 in 800
Fitness: 1.5063636 in 900
Fitness: 1.5132088 in 1000
Fitness: 1.5205179 in 1100
Fitness: 1.5279514 in 1200
Fitness: 1.5353057 in 1300
Fitness: 1.5427849 in 1400
Fitness: 1.5501786 in 1500
Fitness: 1.5577362 in 1600
Fitness: 1.5655594 in 1700
Fitness: 1.5731292 in 1800
Fitness: 1.5809709 in 1900
Fitness: 1.5887279 in 2000
Fitness: 1.5951970 in 2100
Fitness: 1.6011106 in 2200
Fitness: 1.6068187 in 2300
Fitness: 1.6123935 in 2400
Fitness: 1.6180653 in 2500
Fitness: 1.6238077 in 2600
Fitness: 1.6296585 in 2700
Fitness: 1.6355123 in 2800
Fitness: 1.6414985 in 2900
Fitness: 1.6474230 in 3000
Fitness: 1.6533818 in 3100
Fitness: 1.6595405 in 3200
Fitness: 1.6656350 in 3300
Fitness: 1.6719877 in 3400
Fitness: 1.6783297 in 3500
Fitness: 1.6829903 in 3600
Fitness: 1.6873849 in 3700
Fitness: 1.6911576 in 3800
Fitness: 1.6937172 in 3900
Fitness: 1.6961818 in 4000
Fitness: 1.6987517 in 4100
Fitness: 1.7012792 in 4200
Fitness: 1.7037597 in 4300
Fitness: 1.7063068 in 4400
Fitness: 1.7085905 in 4500
Fitness: 1.7108070 in 4600
Fitness: 1.7130101 in 4700
Fitness: 1.7152127 in 4800
Fitness: 1.7173509 in 4900
Fitness: 1.7192078 in 5000
Fitness: 1.7211398 in 5100
Fitness: 1.7230811 in 5200
Fitness: 1.7247623 in 5300
Fitness: 1.7265035 in 5400
Fitness: 1.7282836 in 5500
Fitness: 1.7298525 in 5600
Fitness: 1.7314503 in 5700
Fitness: 1.7329108 in 5800
Fitness: 1.7344369 in 5900
Fitness: 1.7358473 in 6000
Fitness: 1.7372115 in 6100
Fitness: 1.7385740 in 6200
Fitness: 1.7399730 in 6300
Fitness: 1.7411238 in 6400
Fitness: 1.7424066 in 6500
Fitness: 1.7436489 in 6600
Fitness: 1.7447034 in 6700
Fitness: 1.7458695 in 6800
Fitness: 1.7469952 in 6900
Fitness: 1.7479812 in 7000
Fitness: 1.7489899 in 7100
Fitness: 1.7499906 in 7200
Fitness: 1.7508502 in 7300
Fitness: 1.7517418 in 7400
Fitness: 1.7526096 in 7500
Fitness: 1.7534293 in 7600
Fitness: 1.7541068 in 7700
Fitness: 1.7548324 in 7800
Fitness: 1.7555052 in 7900
Fitness: 1.7560482 in 8000
Fitness: 1.7566162 in 8100
Fitness: 1.7571203 in 8200
Fitness: 1.7575131 in 8300
Fitness: 1.7579033 in 8400
Fitness: 1.7582263 in 8500
Fitness: 1.7584498 in 8600
Fitness: 1.7586363 in 8700
Fitness: 1.7587468 in 8800
Fitness: 1.7587688 in 8900
Fitness: 1.7587688 in 9000
Fitness: 1.7587688 in 9100
Calibration complete
Calibration values:
Fitness: 1.7587686930730544
Maslow_tlX: -14.9
Maslow_tlY: 2676.4
Maslow_trX: 3081.7
Maslow_trY: 2690.3
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3086.1
Maslow_brY: 0.0
These values have been automatically saved for you.
You MUST restart your machine for them to take effect…I know that is annoying, it’s getting fixed ASAP.
I think this is the highest fitness number I have reached so far. I have only turn the Maslow off now, I have not restarted it yet. I thought I’d wait for your reactions first. But it might have been better than before, I do not remember the exact fitness numbers but I remember them being under 1 and in later tries maybe 1,1 or1,2 that area, not 1,75 that is the highest so far I think.
This does look good, except it should have started the next “ring” of movement after saving the initial fitness… did you wait a while after seeing this final message or just turn off right away? Also just to make sure, you did install the latest index.html.gz that went along with the firmware, right?
No, I did not use a new index.html.gz since I thought it wouldn’t matter, I thought that was purely cosmetic. I did not wait for very long after the machine stopped doing anything. 1 to 5 minutes I guess in my several tries so far. None of the times did it continue anything… And the last sentence in the message said I had to restart the machine, so I did do that.
So I should install the latest Index file too? I have only updated the firmware file and the maslow.yaml file. I will install all anew and try again and post the message and after calibration I will just keep waiting to see if other things happen.
Thank you very much so far.
Yes, you should always install firmware.bin as upload firmware, and index.html.gz as a file, ESPECIALLY for calibration. All the calibration computations are in the html file. the maslow just sends measurements to the ui and it does the calculations and tells maslow what to do.
Thank you for your reply I am busy trying right now:)
Just tried it out, was much much better.
This time it did calibrate again after calculating, and again after that.
It didn’t have much confidence in the results though so it warned me not to use them.
I tried to make my set up a little more stable and perhaps this time, since it seems to be going ok now, I will run it without the blanket I had under it for protection. Maybe that was too soft to give stable results.
Anyway thanks a lot for now I will run it again until I get better results and then I will try the xy panel to see if it works better.
In the last of the calibration runs the slack was much less so I think it is going the right way.
Will let you know if/when it works ![]()
Worked better again, calibrated twice. While calibrating it spits out less changing numbers as if there is less to compensate for / the accuracy is getting there? Just my feeling about it.
Went better but still when i move around with the x/y the belts have much slack and I am worried to use it like that when cutting with the router on…
Anyway, enough for today, thank you all, especially @ronlawrence3 and @dlang.
More tomorrow, maybe I’ll try a small cut and see how it goes.
Last Serial messages:
Serial Messages
[MSG:ERR: Cannot take slack until all axis are extended fully]
[MSG:ERR: Please press Retract All before using Extend All]
[MSG:INFO: Top Left pulled tight with offset -13.377]
[MSG:INFO: Bottom Right pulled tight with offset -8.514]
[MSG:INFO: Bottom Left pulled tight with offset -25.713]
[MSG:INFO: Bottom Left pulled tight with offset -1882.261]
[MSG:INFO: Top Left pulled tight with offset -1886.223]
[MSG:INFO: Bottom Right pulled tight with offset -1902.176]
[MSG:INFO: Top Right pulled tight with offset -1897.538]
error:82
[MSG:INFO: Center point deviation: TL: 0.118 TR: 0.331 BL: -11.995 BR: -10.805]
CLBM:[{bl:2037.38, br:2040.54, tr:2050.63, tl:2053.17},{bl:1969.55, br:1971.73, tr:2126.11, tl:2127.62},{bl:1780.49, br:2162.70, tr:2312.76, tl:1964.22},{bl:1858.18, br:2235.88, tr:2244.76, tl:1872.48},{bl:1949.30, br:2312.23, tr:2172.16, tl:1784.74},{bl:2123.74, br:2135.54, tr:1970.81, tl:1964.03},{bl:2309.76, br:1962.33, tr:1781.70, tl:2164.93},{bl:2243.73, br:1870.54, tr:1862.80, tl:2238.47},{bl:2171.09, br:1782.77, tr:1954.18, tl:2315.57},]
Computing… This may take several minutesFitness: 1.2156265 in 100
Fitness: 1.2179926 in 200
Fitness: 1.2179926 in 300
Fitness: 1.2179926 in 400
Fitness: 1.2179926 in 500
Fitness: 1.2179926 in 600
Fitness: 1.2179926 in 700
Fitness: 1.2179926 in 800
Fitness: 1.2179926 in 900
Fitness: 1.2179926 in 1000
Fitness: 1.2179926 in 1100
Calibration values:
Fitness: 1.217992526641455
Maslow_tlX: -4.4
Maslow_tlY: 2684.6
Maslow_trX: 3081.6
Maslow_trY: 2691.0
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3087.9
Maslow_brY: 0.0
error:82
[MSG:INFO: Measured waypoint 9]
[MSG:INFO: Measured waypoint 10]
[MSG:INFO: Measured waypoint 11]
[MSG:INFO: Measured waypoint 12]
[MSG:INFO: Measured waypoint 13]
[MSG:INFO: Measured waypoint 14]
[MSG:INFO: Measured waypoint 15]
[MSG:INFO: Measured waypoint 16]
[MSG:INFO: Measured waypoint 17]
[MSG:INFO: Measured waypoint 18]
[MSG:INFO: Measured waypoint 19]
[MSG:INFO: Measured waypoint 20]
[MSG:INFO: Measured waypoint 21]
[MSG:INFO: Measured waypoint 22]
[MSG:INFO: Measured waypoint 23]
[MSG:INFO: Measured waypoint 24]
CLBM:[{bl:2037.38, br:2040.54, tr:2050.63, tl:2053.17},{bl:1969.55, br:1971.73, tr:2126.11, tl:2127.62},{bl:1780.49, br:2162.70, tr:2312.76, tl:1964.22},{bl:1858.18, br:2235.88, tr:2244.76, tl:1872.48},{bl:1949.30, br:2312.23, tr:2172.16, tl:1784.74},{bl:2123.74, br:2135.54, tr:1970.81, tl:1964.03},{bl:2309.76, br:1962.33, tr:1781.70, tl:2164.93},{bl:2243.73, br:1870.54, tr:1862.80, tl:2238.47},{bl:2171.09, br:1782.77, tr:1954.18, tl:2315.57},{bl:2098.83, br:1702.31, tr:2052.34, tl:2392.19},{bl:1890.31, br:1892.40, tr:2218.16, tl:2221.20},{bl:1692.92, br:2101.19, tr:2398.84, tl:2055.24},{bl:1511.33, br:2315.64, tr:2589.43, tl:1907.85},{bl:1600.68, br:2378.22, tr:2519.07, tl:1804.99},{bl:1697.10, br:2443.55, tr:2448.15, tl:1705.08},{bl:1797.97, br:2514.13, tr:2381.71, tl:1608.63},{bl:1899.16, br:2587.60, tr:2320.11, tl:1516.47},{bl:2048.45, br:2406.25, tr:2103.60, tl:1690.29},{bl:2212.81, br:2225.65, tr:1895.08, tl:1888.04},{bl:2391.86, br:2059.55, tr:1697.85, tl:2096.46},{bl:2581.89, br:1911.83, tr:1516.34, tl:2312.62},{bl:2514.70, br:1808.96, tr:1605.79, tl:2373.70},{bl:2443.79, br:1709.02, tr:1702.05, tl:2439.96},{bl:2377.30, br:1612.46, tr:1803.10, tl:2511.28},{bl:2315.67, br:1520.17, tr:1906.94, tl:2585.84},]
Computing… This may take several minutesFitness: 1.0299976 in 100
Fitness: 1.0299976 in 200
Fitness: 1.0299976 in 300
Fitness: 1.0299976 in 400
Fitness: 1.0299976 in 500
Fitness: 1.0299976 in 600
Fitness: 1.0299976 in 700
Fitness: 1.0299976 in 800
Fitness: 1.0299976 in 900
Fitness: 1.0299976 in 1000
Calibration values:
Fitness: 1.0299976516053544
Maslow_tlX: -5.7
Maslow_tlY: 2683.3
Maslow_trX: 3081.6
Maslow_trY: 2691.9
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3087.9
Maslow_brY: 0.0
error:82
[MSG:INFO: Measured waypoint 25]
[MSG:INFO: Measured waypoint 26]
[MSG:INFO: Measured waypoint 27]
[MSG:INFO: Measured waypoint 28]
[MSG:INFO: Measured waypoint 29]
[MSG:ERR: Measurement error, measurements are not within 2.5 mm of each other, trying again]
[MSG:INFO: Max deviation: 2.738]
[MSG:INFO: Bottom Right 1894.932]
[MSG:INFO: Bottom Right 1895.018]
[MSG:INFO: Bottom Right 1895.029]
[MSG:INFO: Bottom Right 1895.050]
[MSG:INFO: Top Right 2865.260]
[MSG:INFO: Top Right 2865.185]
[MSG:INFO: Top Right 2865.163]
[MSG:INFO: Top Left 1251.583]
[MSG:INFO: Top Left 1251.658]
[MSG:INFO: Top Left 1251.637]
[MSG:INFO: Bottom Left 2490.409]
[MSG:INFO: Bottom Left 2487.672]
[MSG:INFO: Bottom Left 2487.586]
[MSG:INFO: Measured waypoint 30]
[MSG:INFO: Measured waypoint 31]
[MSG:INFO: Measured waypoint 32]
[MSG:INFO: Measured waypoint 33]
[MSG:INFO: Measured waypoint 34]
[MSG:INFO: Measured waypoint 35]
[MSG:INFO: Measured waypoint 36]
[MSG:INFO: Measured waypoint 37]
[MSG:INFO: Measured waypoint 38]
[MSG:INFO: Measured waypoint 39]
[MSG:INFO: Measured waypoint 40]
[MSG:INFO: Measured waypoint 41]
[MSG:INFO: Measured waypoint 42]
[MSG:INFO: Measured waypoint 43]
[MSG:INFO: Measured waypoint 44]
[MSG:INFO: Measured waypoint 45]
[MSG:INFO: Measured waypoint 46]
[MSG:INFO: Measured waypoint 47]
[MSG:INFO: Measured waypoint 48]
CLBM:[{bl:2037.38, br:2040.54, tr:2050.63, tl:2053.17},{bl:1969.55, br:1971.73, tr:2126.11, tl:2127.62},{bl:1780.49, br:2162.70, tr:2312.76, tl:1964.22},{bl:1858.18, br:2235.88, tr:2244.76, tl:1872.48},{bl:1949.30, br:2312.23, tr:2172.16, tl:1784.74},{bl:2123.74, br:2135.54, tr:1970.81, tl:1964.03},{bl:2309.76, br:1962.33, tr:1781.70, tl:2164.93},{bl:2243.73, br:1870.54, tr:1862.80, tl:2238.47},{bl:2171.09, br:1782.77, tr:1954.18, tl:2315.57},{bl:2098.83, br:1702.31, tr:2052.34, tl:2392.19},{bl:1890.31, br:1892.40, tr:2218.16, tl:2221.20},{bl:1692.92, br:2101.19, tr:2398.84, tl:2055.24},{bl:1511.33, br:2315.64, tr:2589.43, tl:1907.85},{bl:1600.68, br:2378.22, tr:2519.07, tl:1804.99},{bl:1697.10, br:2443.55, tr:2448.15, tl:1705.08},{bl:1797.97, br:2514.13, tr:2381.71, tl:1608.63},{bl:1899.16, br:2587.60, tr:2320.11, tl:1516.47},{bl:2048.45, br:2406.25, tr:2103.60, tl:1690.29},{bl:2212.81, br:2225.65, tr:1895.08, tl:1888.04},{bl:2391.86, br:2059.55, tr:1697.85, tl:2096.46},{bl:2581.89, br:1911.83, tr:1516.34, tl:2312.62},{bl:2514.70, br:1808.96, tr:1605.79, tl:2373.70},{bl:2443.79, br:1709.02, tr:1702.05, tl:2439.96},{bl:2377.30, br:1612.46, tr:1803.10, tl:2511.28},{bl:2315.67, br:1520.17, tr:1906.94, tl:2585.84},{bl:2258.29, br:1433.24, tr:2011.71, tl:2663.73},{bl:2035.45, br:1618.22, tr:2154.93, tl:2485.80},{bl:1819.77, br:1824.13, tr:2310.87, tl:2311.84},{bl:1613.90, br:2040.41, tr:2486.05, tl:2152.88},{bl:1422.36, br:2262.52, tr:2671.66, tl:2012.59},{bl:1251.65, br:2487.61, tr:2865.11, tl:1894.99},{bl:1347.09, br:2540.42, tr:2796.65, tl:1782.76},{bl:1450.86, br:2595.70, tr:2727.17, tl:1672.28},{bl:1557.07, br:2656.67, tr:2661.72, tl:1563.93},{bl:1665.55, br:2720.99, tr:2600.66, tl:1458.33},{bl:1774.71, br:2789.77, tr:2544.29, tl:1355.99},{bl:1886.65, br:2861.78, tr:2492.93, tl:1257.79},{bl:2007.98, br:2677.44, tr:2265.23, tl:1420.17},{bl:2146.49, br:2491.24, tr:2042.58, tl:1612.26},{bl:2303.28, br:2317.15, tr:1827.06, tl:1818.13},{bl:2474.61, br:2158.04, tr:1621.56, tl:2032.72},{bl:2658.67, br:2017.44, tr:1430.13, tl:2254.62},{bl:2851.99, br:1899.60, tr:1259.40, tl:2479.60},{bl:2789.85, br:1787.15, tr:1353.17, tl:2535.06},{bl:2720.39, br:1676.60, tr:1455.09, tl:2592.11},{bl:2654.95, br:1568.24, tr:1570.06, tl:2647.92},{bl:2593.94, br:1462.59, tr:1670.35, tl:2716.49},{bl:2537.61, br:1360.19, tr:1779.21, tl:2785.59},{bl:2486.27, br:1261.86, tr:1890.99, tl:2858.56},]
Computing… This may take several minutesFitness: 0.8522761 in 100
Fitness: 0.8522761 in 200
Fitness: 0.8522761 in 300
Fitness: 0.8522761 in 400
Fitness: 0.8522761 in 500
Fitness: 0.8522761 in 600
Fitness: 0.8522761 in 700
Fitness: 0.8522761 in 800
Fitness: 0.8522761 in 900
Fitness: 0.8522761 in 1000
Calibration values:
Fitness: 0.8522761654322583
Maslow_tlX: -5.8
Maslow_tlY: 2683.3
Maslow_trX: 3082.2
Maslow_trY: 2691.9
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3087.9
Maslow_brY: 0.0
error:82
[MSG:INFO: Measured waypoint 49]
[MSG:INFO: Measured waypoint 50]
[MSG:INFO: Measured waypoint 51]
[MSG:INFO: Measured waypoint 52]
[MSG:INFO: Measured waypoint 53]
[MSG:INFO: Measured waypoint 54]
[MSG:INFO: Measured waypoint 55]
[MSG:INFO: Measured waypoint 56]
[MSG:INFO: Measured waypoint 57]
[MSG:INFO: Measured waypoint 58]
[MSG:INFO: Measured waypoint 59]
[MSG:INFO: Measured waypoint 60]
[MSG:INFO: Measured waypoint 61]
[MSG:INFO: Measured waypoint 62]
[MSG:INFO: Measured waypoint 63]
[MSG:INFO: Measured waypoint 64]
[MSG:INFO: Measured waypoint 65]
[MSG:INFO: Measured waypoint 66]
[MSG:INFO: Measured waypoint 67]
[MSG:INFO: Measured waypoint 68]
[MSG:INFO: Measured waypoint 69]
[MSG:INFO: Measured waypoint 70]
[MSG:INFO: Measured waypoint 71]
[MSG:INFO: Measured waypoint 72]
[MSG:INFO: Measured waypoint 73]
[MSG:INFO: Measured waypoint 74]
[MSG:INFO: Measured waypoint 75]
[MSG:INFO: Measured waypoint 76]
[MSG:INFO: Measured waypoint 77]
[MSG:INFO: Measured waypoint 78]
[MSG:INFO: Measured waypoint 79]
[MSG:INFO: Measured waypoint 80]
CLBM:[{bl:2037.38, br:2040.54, tr:2050.63, tl:2053.17},{bl:1969.55, br:1971.73, tr:2126.11, tl:2127.62},{bl:1780.49, br:2162.70, tr:2312.76, tl:1964.22},{bl:1858.18, br:2235.88, tr:2244.76, tl:1872.48},{bl:1949.30, br:2312.23, tr:2172.16, tl:1784.74},{bl:2123.74, br:2135.54, tr:1970.81, tl:1964.03},{bl:2309.76, br:1962.33, tr:1781.70, tl:2164.93},{bl:2243.73, br:1870.54, tr:1862.80, tl:2238.47},{bl:2171.09, br:1782.77, tr:1954.18, tl:2315.57},{bl:2098.83, br:1702.31, tr:2052.34, tl:2392.19},{bl:1890.31, br:1892.40, tr:2218.16, tl:2221.20},{bl:1692.92, br:2101.19, tr:2398.84, tl:2055.24},{bl:1511.33, br:2315.64, tr:2589.43, tl:1907.85},{bl:1600.68, br:2378.22, tr:2519.07, tl:1804.99},{bl:1697.10, br:2443.55, tr:2448.15, tl:1705.08},{bl:1797.97, br:2514.13, tr:2381.71, tl:1608.63},{bl:1899.16, br:2587.60, tr:2320.11, tl:1516.47},{bl:2048.45, br:2406.25, tr:2103.60, tl:1690.29},{bl:2212.81, br:2225.65, tr:1895.08, tl:1888.04},{bl:2391.86, br:2059.55, tr:1697.85, tl:2096.46},{bl:2581.89, br:1911.83, tr:1516.34, tl:2312.62},{bl:2514.70, br:1808.96, tr:1605.79, tl:2373.70},{bl:2443.79, br:1709.02, tr:1702.05, tl:2439.96},{bl:2377.30, br:1612.46, tr:1803.10, tl:2511.28},{bl:2315.67, br:1520.17, tr:1906.94, tl:2585.84},{bl:2258.29, br:1433.24, tr:2011.71, tl:2663.73},{bl:2035.45, br:1618.22, tr:2154.93, tl:2485.80},{bl:1819.77, br:1824.13, tr:2310.87, tl:2311.84},{bl:1613.90, br:2040.41, tr:2486.05, tl:2152.88},{bl:1422.36, br:2262.52, tr:2671.66, tl:2012.59},{bl:1251.65, br:2487.61, tr:2865.11, tl:1894.99},{bl:1347.09, br:2540.42, tr:2796.65, tl:1782.76},{bl:1450.86, br:2595.70, tr:2727.17, tl:1672.28},{bl:1557.07, br:2656.67, tr:2661.72, tl:1563.93},{bl:1665.55, br:2720.99, tr:2600.66, tl:1458.33},{bl:1774.71, br:2789.77, tr:2544.29, tl:1355.99},{bl:1886.65, br:2861.78, tr:2492.93, tl:1257.79},{bl:2007.98, br:2677.44, tr:2265.23, tl:1420.17},{bl:2146.49, br:2491.24, tr:2042.58, tl:1612.26},{bl:2303.28, br:2317.15, tr:1827.06, tl:1818.13},{bl:2474.61, br:2158.04, tr:1621.56, tl:2032.72},{bl:2658.67, br:2017.44, tr:1430.13, tl:2254.62},{bl:2851.99, br:1899.60, tr:1259.40, tl:2479.60},{bl:2789.85, br:1787.15, tr:1353.17, tl:2535.06},{bl:2720.39, br:1676.60, tr:1455.09, tl:2592.11},{bl:2654.95, br:1568.24, tr:1570.06, tl:2647.92},{bl:2593.94, br:1462.59, tr:1670.35, tl:2716.49},{bl:2537.61, br:1360.19, tr:1779.21, tl:2785.59},{bl:2486.27, br:1261.86, tr:1890.99, tl:2858.56},{bl:2440.34, br:1168.34, tr:2004.48, tl:2935.24},{bl:2207.64, br:1344.31, tr:2118.94, tl:2753.94},{bl:1979.07, br:1547.30, tr:2252.98, tl:2573.81},{bl:1756.47, br:1762.22, tr:2404.03, tl:2406.19},{bl:1542.11, br:1984.60, tr:2573.65, tl:2253.89},{bl:1340.41, br:2211.92, tr:2751.90, tl:2120.30},{bl:1157.54, br:2443.29, tr:2942.67, tl:2008.99},{bl:1004.15, br:2674.77, tr:3137.62, tl:1923.96},{bl:1109.57, br:2720.48, tr:3073.80, tl:1804.81},{bl:1219.04, br:2765.90, tr:3005.53, tl:1686.52},{bl:1331.22, br:2818.64, tr:2940.98, tl:1569.23},{bl:1446.88, br:2874.08, tr:2880.41, tl:1453.25},{bl:1563.58, br:2934.26, tr:2824.07, tl:1338.96},{bl:1679.58, br:2997.06, tr:2772.21, tl:1226.66},{bl:1797.41, br:3064.95, tr:2725.12, tl:1117.16},{bl:1915.14, br:3135.41, tr:2683.01, tl:1011.14},{bl:2006.37, br:2949.57, tr:2447.44, tl:1154.74},{bl:2114.91, br:2759.12, tr:2214.88, tl:1339.53},{bl:2246.81, br:2578.87, tr:1986.59, tl:1542.04},{bl:2396.80, br:2411.10, tr:1764.22, tl:1755.59},{bl:2563.28, br:2258.60, tr:1550.12, tl:1977.35},{bl:2741.48, br:2124.69, tr:1348.67, tl:2203.92},{bl:2929.21, br:2013.17, tr:1166.15, tl:2433.50},{bl:3123.27, br:1927.69, tr:1012.59, tl:2663.10},{bl:3066.63, br:1808.39, tr:1114.74, tl:2712.02},{bl:2998.37, br:1690.03, tr:1222.75, tl:2761.02},{bl:2933.82, br:1572.64, tr:1334.37, tl:2814.20},{bl:2873.30, br:1456.64, tr:1447.79, tl:2870.83},{bl:2817.02, br:1342.20, tr:1576.53, tl:2921.30},{bl:2765.22, br:1229.75, tr:1682.48, tl:2994.28},{bl:2718.22, br:1120.05, tr:1799.68, tl:3061.80},{bl:2676.18, br:1013.81, tr:1919.35, tl:3133.55},]
Computing… This may take several minutesFitness: 0.6735942 in 100
Fitness: 0.6736019 in 200
Fitness: 0.6736019 in 300
Fitness: 0.6736019 in 400
Fitness: 0.6736019 in 500
Fitness: 0.6736019 in 600
Fitness: 0.6736019 in 700
Fitness: 0.6736019 in 800
Fitness: 0.6736019 in 900
Fitness: 0.6736019 in 1000
Fitness: 0.6736019 in 1100
Calibration values:
Fitness: 0.6736018921207709
Maslow_tlX: -5.4
Maslow_tlY: 2683.3
Maslow_trX: 3085.4
Maslow_trY: 2689.1
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3088.6
Maslow_brY: 0.0
error:82
[MSG:INFO: Measured waypoint 81]
[MSG:INFO: Measured waypoint 82]
CLBM:[{bl:2037.38, br:2040.54, tr:2050.63, tl:2053.17},{bl:1969.55, br:1971.73, tr:2126.11, tl:2127.62},{bl:1780.49, br:2162.70, tr:2312.76, tl:1964.22},{bl:1858.18, br:2235.88, tr:2244.76, tl:1872.48},{bl:1949.30, br:2312.23, tr:2172.16, tl:1784.74},{bl:2123.74, br:2135.54, tr:1970.81, tl:1964.03},{bl:2309.76, br:1962.33, tr:1781.70, tl:2164.93},{bl:2243.73, br:1870.54, tr:1862.80, tl:2238.47},{bl:2171.09, br:1782.77, tr:1954.18, tl:2315.57},{bl:2098.83, br:1702.31, tr:2052.34, tl:2392.19},{bl:1890.31, br:1892.40, tr:2218.16, tl:2221.20},{bl:1692.92, br:2101.19, tr:2398.84, tl:2055.24},{bl:1511.33, br:2315.64, tr:2589.43, tl:1907.85},{bl:1600.68, br:2378.22, tr:2519.07, tl:1804.99},{bl:1697.10, br:2443.55, tr:2448.15, tl:1705.08},{bl:1797.97, br:2514.13, tr:2381.71, tl:1608.63},{bl:1899.16, br:2587.60, tr:2320.11, tl:1516.47},{bl:2048.45, br:2406.25, tr:2103.60, tl:1690.29},{bl:2212.81, br:2225.65, tr:1895.08, tl:1888.04},{bl:2391.86, br:2059.55, tr:1697.85, tl:2096.46},{bl:2581.89, br:1911.83, tr:1516.34, tl:2312.62},{bl:2514.70, br:1808.96, tr:1605.79, tl:2373.70},{bl:2443.79, br:1709.02, tr:1702.05, tl:2439.96},{bl:2377.30, br:1612.46, tr:1803.10, tl:2511.28},{bl:2315.67, br:1520.17, tr:1906.94, tl:2585.84},{bl:2258.29, br:1433.24, tr:2011.71, tl:2663.73},{bl:2035.45, br:1618.22, tr:2154.93, tl:2485.80},{bl:1819.77, br:1824.13, tr:2310.87, tl:2311.84},{bl:1613.90, br:2040.41, tr:2486.05, tl:2152.88},{bl:1422.36, br:2262.52, tr:2671.66, tl:2012.59},{bl:1251.65, br:2487.61, tr:2865.11, tl:1894.99},{bl:1347.09, br:2540.42, tr:2796.65, tl:1782.76},{bl:1450.86, br:2595.70, tr:2727.17, tl:1672.28},{bl:1557.07, br:2656.67, tr:2661.72, tl:1563.93},{bl:1665.55, br:2720.99, tr:2600.66, tl:1458.33},{bl:1774.71, br:2789.77, tr:2544.29, tl:1355.99},{bl:1886.65, br:2861.78, tr:2492.93, tl:1257.79},{bl:2007.98, br:2677.44, tr:2265.23, tl:1420.17},{bl:2146.49, br:2491.24, tr:2042.58, tl:1612.26},{bl:2303.28, br:2317.15, tr:1827.06, tl:1818.13},{bl:2474.61, br:2158.04, tr:1621.56, tl:2032.72},{bl:2658.67, br:2017.44, tr:1430.13, tl:2254.62},{bl:2851.99, br:1899.60, tr:1259.40, tl:2479.60},{bl:2789.85, br:1787.15, tr:1353.17, tl:2535.06},{bl:2720.39, br:1676.60, tr:1455.09, tl:2592.11},{bl:2654.95, br:1568.24, tr:1570.06, tl:2647.92},{bl:2593.94, br:1462.59, tr:1670.35, tl:2716.49},{bl:2537.61, br:1360.19, tr:1779.21, tl:2785.59},{bl:2486.27, br:1261.86, tr:1890.99, tl:2858.56},{bl:2440.34, br:1168.34, tr:2004.48, tl:2935.24},{bl:2207.64, br:1344.31, tr:2118.94, tl:2753.94},{bl:1979.07, br:1547.30, tr:2252.98, tl:2573.81},{bl:1756.47, br:1762.22, tr:2404.03, tl:2406.19},{bl:1542.11, br:1984.60, tr:2573.65, tl:2253.89},{bl:1340.41, br:2211.92, tr:2751.90, tl:2120.30},{bl:1157.54, br:2443.29, tr:2942.67, tl:2008.99},{bl:1004.15, br:2674.77, tr:3137.62, tl:1923.96},{bl:1109.57, br:2720.48, tr:3073.80, tl:1804.81},{bl:1219.04, br:2765.90, tr:3005.53, tl:1686.52},{bl:1331.22, br:2818.64, tr:2940.98, tl:1569.23},{bl:1446.88, br:2874.08, tr:2880.41, tl:1453.25},{bl:1563.58, br:2934.26, tr:2824.07, tl:1338.96},{bl:1679.58, br:2997.06, tr:2772.21, tl:1226.66},{bl:1797.41, br:3064.95, tr:2725.12, tl:1117.16},{bl:1915.14, br:3135.41, tr:2683.01, tl:1011.14},{bl:2006.37, br:2949.57, tr:2447.44, tl:1154.74},{bl:2114.91, br:2759.12, tr:2214.88, tl:1339.53},{bl:2246.81, br:2578.87, tr:1986.59, tl:1542.04},{bl:2396.80, br:2411.10, tr:1764.22, tl:1755.59},{bl:2563.28, br:2258.60, tr:1550.12, tl:1977.35},{bl:2741.48, br:2124.69, tr:1348.67, tl:2203.92},{bl:2929.21, br:2013.17, tr:1166.15, tl:2433.50},{bl:3123.27, br:1927.69, tr:1012.59, tl:2663.10},{bl:3066.63, br:1808.39, tr:1114.74, tl:2712.02},{bl:2998.37, br:1690.03, tr:1222.75, tl:2761.02},{bl:2933.82, br:1572.64, tr:1334.37, tl:2814.20},{bl:2873.30, br:1456.64, tr:1447.79, tl:2870.83},{bl:2817.02, br:1342.20, tr:1576.53, tl:2921.30},{bl:2765.22, br:1229.75, tr:1682.48, tl:2994.28},{bl:2718.22, br:1120.05, tr:1799.68, tl:3061.80},{bl:2676.18, br:1013.81, tr:1919.35, tl:3133.55},{bl:1757.60, br:1760.10, tr:2403.12, tl:2408.00},{bl:2038.12, br:2045.09, tr:2051.79, tl:2051.37},]
Computing… This may take several minutesFitness: 0.6677312 in 100
Fitness: 0.6677312 in 200
Fitness: 0.6677312 in 300
Fitness: 0.6677312 in 400
Fitness: 0.6677312 in 500
Fitness: 0.6677312 in 600
Fitness: 0.6677312 in 700
Fitness: 0.6677312 in 800
Fitness: 0.6677312 in 900
Fitness: 0.6677312 in 1000
Calibration values:
Fitness: 0.6677311636878178
Maslow_tlX: -5.4
Maslow_tlY: 2683.3
Maslow_trX: 3085.5
Maslow_trY: 2688.9
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3088.6
Maslow_brY: 0.0
error:82
[MSG:INFO: Calibration complete]
That error 82 is new to me. It supposedly means that fluidNC failed to create a file: Alarm and Error Codes | Wiki.js
It might be worth double checking that the computed values were saved into your settings properly
Where do I check those? Do you mean in the Setup Config ? And there the frame size? What exactly do I check?
download the maslow.yaml file from the fluidnc tab/files and have a look inside. it should reflect the latest numbers in your output.
Thank you.
Here is what is in the maslow.yaml file:
board: Maslow
name: Maslow S3 Board
meta:
Maslow_vertical: false
maslow_calibration_grid_width_mm_X: 2000.000000
maslow_calibration_grid_height_mm_Y: 1000.000000
maslow_calibration_grid_size: 9
Maslow_brX: 3088.000000
Maslow_brY: 0.000000
Maslow_brZ: 117.000000
Maslow_tlX: 0.000000
Maslow_tlY: 2691.000000
Maslow_tlZ: 144.000000
Maslow_trX: 3088.000000
Maslow_trY: 2691.000000
Maslow_trZ: 97.000000
Maslow_blX: 0.000000
Maslow_blY: 0.000000
Maslow_blZ: 75.000000
Maslow_Retract_Current_Threshold: 1300
Maslow_Calibration_Current_Threshold: 1300
stepping:
engine: Timed
idle_ms: 240
pulse_us: 4
dir_delay_us: 0
disable_delay_us: 0
segments: 12
uart1:
txd_pin: gpio.1
rxd_pin: gpio.2
rts_pin: NO_PIN
cts_pin: NO_PIN
baud: 115200
mode: 8N1
spi:
miso_pin: gpio.13
mosi_pin: gpio.11
sck_pin: gpio.12
sdcard:
cs_pin: gpio.10
card_detect_pin: NO_PIN
frequency_hz: 8000000
kinematics:
Cartesian:
axes:
shared_stepper_disable_pin: NO_PIN
shared_stepper_reset_pin: NO_PIN
x:
steps_per_mm: 80.000000
max_rate_mm_per_min: 2000.000000
acceleration_mm_per_sec2: 25.000000
max_travel_mm: 2438.399902
soft_limits: false
homing:
cycle: -1
allow_single_axis: true
positive_direction: true
mpos_mm: 0.000000
feed_mm_per_min: 50.000000
seek_mm_per_min: 200.000000
settle_ms: 250
seek_scaler: 1.100000
feed_scaler: 1.100000
motor0:
limit_neg_pin: NO_PIN
limit_pos_pin: NO_PIN
limit_all_pin: NO_PIN
hard_limits: false
pulloff_mm: 1.000000
dc_servo:
timer_ms: 10
y:
max_travel_mm: 1219.199951
soft_limits: false
homing:
cycle: -1
mpos_mm: 0.000000
settle_ms: 250
motor0:
hard_limits: false
null_motor:
z:
steps_per_mm: 100.000000
max_rate_mm_per_min: 400.000000
acceleration_mm_per_sec2: 10.000000
max_travel_mm: 100.000000
soft_limits: false
homing:
cycle: -1
mpos_mm: 0.000000
settle_ms: 250
motor0:
hard_limits: false
tmc_2209:
uart_num: 1
step_pin: gpio.15
direction_pin: gpio.16
disable_pin: NO_PIN
r_sense_ohms: 0.110000
run_amps: 1.000000
hold_amps: 0.500000
microsteps: 1
toff_disable: 0
toff_stealthchop: 5
use_enable: true
addr: 0
run_mode: StealthChop
homing_mode: StealthChop
stallguard: 0
stallguard_debug: false
toff_coolstep: 3
motor1:
hard_limits: false
tmc_2209:
uart_num: 1
step_pin: gpio.46
direction_pin: gpio.38
disable_pin: NO_PIN
run_amps: 1.000000
hold_amps: 0.500000
microsteps: 1
toff_disable: 0
toff_stealthchop: 5
use_enable: true
addr: 1
stallguard: 0
toff_coolstep: 3
control:
safety_door_pin: NO_PIN
reset_pin: NO_PIN
feed_hold_pin: NO_PIN
cycle_start_pin: NO_PIN
macro0_pin: NO_PIN
macro1_pin: NO_PIN
macro2_pin: NO_PIN
macro3_pin: NO_PIN
coolant:
flood_pin: NO_PIN
mist_pin: NO_PIN
delay_ms: 0
probe:
pin: NO_PIN
check_mode_start: true
macros:
startup_line0:
startup_line1:
macro0:
macro1:
macro2:
macro3:
start:
must_home: true
deactivate_parking: false
check_limits: false
parking:
enable: false
axis: Z
target_mpos_mm: -5.000000
rate_mm_per_min: 800.000000
pullout_distance_mm: 5.000000
pullout_rate_mm_per_min: 250.000000
user_outputs:
analog0_pin: NO_PIN
analog1_pin: NO_PIN
analog2_pin: NO_PIN
analog3_pin: NO_PIN
analog0_hz: 5000
analog1_hz: 5000
analog2_hz: 5000
analog3_hz: 5000
digital0_pin: NO_PIN
digital1_pin: NO_PIN
digital2_pin: NO_PIN
digital3_pin: NO_PIN
digital4_pin: NO_PIN
digital5_pin: NO_PIN
digital6_pin: NO_PIN
digital7_pin: NO_PIN
NoSpindle:
arc_tolerance_mm: 0.002000
junction_deviation_mm: 0.010000
verbose_errors: false
report_inches: false
enable_parking_override_control: false
use_line_numbers: false
planner_blocks: 16
Does this look good or not? This is after my last calibration attempt, which the machine thinks was ok, but @bar saw the unfamiliar error82… The values in the beginning 3088 and 2691 are the measurements I put in, not measured by the Maslow.
What I’m looking at are the values for Maslow_xxx in your maslow.yaml file. According to the final output in your log it looks like the final ones were not saved.
You can either run another calibration and hopefully it will save them or change the values by uploading a new yaml file with the values set to what they are in the output above or enter the important ones in the webui.
The values that the calibration sets are:
Maslow_brX
Maslow_tlX
Maslow_tlY
Maslow_trX
Maslow_trY
so by one of those ways, you can set these to be what you have in the final output of your log above, and then you can try jogging around
Thanks I will try rewriting the file, should be faster than calibrating again (and probably failing again)
I tried rewriting the file, it seemed to work better then before but there was still not very much/no tension on the belts while jogging around. More tension then before though.
So I tried calibrating again. Again the error:82.
After that I copied the serial message textbox and then tried to download the maslow.yaml file form the machine like before to see what the values where this time.
It wouldn’t let me, I mean when (after the calibration) i tried to look at the files on the machine memory the file list was empty, waiting didn’t help. Restarted the machine. Then it would show me the files but the size of the yaml had changed to 5k (the original was 3k) and when i download it to look at it it comes out 0.5k and has the following text when i open it:
Captive Portal page : /maslow.yaml- you will be redirected…
if not redirected, click here
And the “click here” part is blue as if it refers to a website.
Did the Error:82 wipe the file and it it therefor redirecting me to a new file online?
I edited the yaml file in Textedit on my mac (old OSX though) is that okay? Should i work it as regular text or as rich text?
