Updating to 0.78 bricked machine?
I upgraded to 0.78. After rebooting I could not connect to it through my home WiFi and it wasn’t presenting its local WiFi. It also seems in a state where it just flash’s the blue led 9 times repeatedly. (Does that suggest anything?)
I’ve power cycled multiple times always with the same result.
I’ve attached a video of the machine blinking. I also think the belt motor leds seem to be blinking in sync which I don’t remember before.
Finally, I’m trying to figure out how I can recover it. I know on Windows there is a bat file that can reset it via usb but I only have Macs. Any ideas?
Video
look for the network fluidnc apparently the merge of the wifi code from upstream
changed the default to that from maslow (and then fluidnc.local instead of
maslow.local)
Hi David, do you have any idea what the default password is for FluidNC network?
Hi Bob. I got it to work again.
Turn off your Wi-fi,
Power reset M4
Connect to wi-fi FluidNC password 12345678
login via fluidnc.local on web browser
Change Config/filename to maslow.yaml
AP/SSID to maslow
and hostname to maslow
Havn’t tested it yet except to move Z axis. Hope this helps.
