I ordered both the open builds one and one from china and they are exactly the same. Only difference is the Chinese one is already put together and costs $44 shipped vs $100 shipped. The open builds one is also totally disassembled to my surprise . what bearings did you wind up adjusting?
that quick release router mount looks very nice. I assume you had to disassemble the black gantry plate and drill and tap some holes on the back of it to mount it to the z axis C beam? How has your maslow been working?
adjustment done as i the video…same time i fitted the clamp,
thanks for the fast response. How is the Makita Router and z axis working out for you? any issues? I think I want to make a similar system. The Makita has good reviews on other CNC machines like Xcarve, MPCNC, and desktop machines.
Makita and z axis working good,no problem so far…
Hi,
Awesome build! Do you have any picture of the frame without the wast board? I am inspired to build one just like this!
Thanks
Dill
No… but its only a 2*4 frame and a 15mm board… and 12mm spoilboard on top of that.
The 15mm boart make the frame stiff.
Thank you! Did you notch the 2x4 cross pieces behind this? So they interlocked and made an X?
What is the distance from the bottom of the 2X8 to the top of the OSB?
What is the distance from the bottom of the 2X8 to the bottom of the frame, where the OSB sits?
That is awesome! Thank you so much!
