I’ve installed Webcontrol on my brandnew Raspberry 400, running Ubuntu 20.10 (64it).
When i try to start the service manually i get the following error:
bs@bs-werkstaette:~/webcontrol$ ./webcontrol
bash: ./webcontrol: cannot execute binary file: Exec format error
The status request gives me:
bs@bs-werkstaette:~/webcontrol$ sudo systemctl status webcontrol
● webcontrol.service - WebControl
Loaded: loaded (/etc/systemd/system/webcontrol.service; enabled; vendor preset: enabled)
Active: failed (Result: exit-code) since Fri 2020-11-27 09:27:12 CET; 35min ago
Process: 761 ExecStart=/home/bs/webcontrol/webcontrol (code=exited, status=217/USER)
Main PID: 761 (code=exited, status=217/USER)
Nov 27 09:27:12 bs-werkstaette systemd[1]: webcontrol.service: Scheduled restart job, restart counter is at 5.
Nov 27 09:27:12 bs-werkstaette systemd[1]: Stopped WebControl.
Nov 27 09:27:12 bs-werkstaette systemd[1]: webcontrol.service: Start request repeated too quickly.
Nov 27 09:27:12 bs-werkstaette systemd[1]: webcontrol.service: Failed with result 'exit-code'.
Nov 27 09:27:12 bs-werkstaette systemd[1]: Failed to start WebControl.
I’ve no idea whats going wrong and the service want start. I’ve tried it as weel as su User.
Kindly ask to help and troubleshot.
Orob
November 27, 2020, 1:23pm
2
which version did you install? The raspberry pi version is for a 32 bit OS. That would be something to check on.
Orob,
i’ve installed the Deban-Version, not the Raspberry Version. Version is
v0.920 on Ubuntu 20.10 (64it).
Regards
Bernhard
Orob
November 27, 2020, 6:48pm
4
I was hoping it would be something easy…
dlang
November 27, 2020, 8:53pm
5
Install the raspberry version, the debian version is setup for x86 processors,
not ARM procssors.
Installed the RPI version now.
When i start it manually it get a
bash: ./webcontrol: No such file or directory
…and yes, i’m in the right directory and the file is here.
The status request gives me now a different error:
bs@bs-werkstaette:~/webcontrol$ systemctl status webcontrol
Active: failed (Result: exit-code) since Sat 2020-11-28 15:31:19 CET; 10s ago
Process: 3433 ExecStart=/home/bs/webcontrol/webcontrol (code=exited, status=203/EXEC)
Main PID: 3433 (code=exited, status=203/EXEC)
Nov 28 15:31:19 bs-werkstaette systemd[1]: webcontrol.service: Scheduled restart job, restart counter is at 5.
Nov 28 15:31:19 bs-werkstaette systemd[1]: Stopped WebControl.
Nov 28 15:31:19 bs-werkstaette systemd[1]: webcontrol.service: Start request repeated too quickly.
Nov 28 15:31:19 bs-werkstaette systemd[1]: webcontrol.service: Failed with result 'exit-code'.
Nov 28 15:31:19 bs-werkstaette systemd[1]: Failed to start WebControl.
Looks like that the 32bit RPI version will not run unter Ubuntu 20.10 (64bit). Also the Ubuntu i386 binary packages are not longer available. Someone any idea?
