What is the measurement of this piece Linear Shaft???
Should be 10mm diameter and 210mm length, but several users have reported errors in length. I ended up with 211 and 212 mm lengths and added shims under the linear rod supports to make things fit.
If your linear shafts are too long, your other option would be to grind them down to 210 mm.
