What screws to use for the corner anchor brackets? and how close do they need to be for whatever size you are going for?
what screws do you all recommend be used on the corner brackets to mount them to the table? and also if I’m going for the 8x12 design do the pins need to be exactly at 8x12 feet or?
the anchors do not need to be precisely positioned, the calibration step is
designed to figure out where they are.
the X axis will be parallel to the two bottom mounts, so you do want to get them
lined up nicely against a reference or you won’t be cutting square to your
table.
thank you @dlang, that is exactly what I was wondering about, I really appreciate the information
we’ve been using Philips bugle - course thread 6 x 1-5/8 Drywall screws, but there are plenty op options out there that will work
