What will the maslow board do if fed by 12v?
@bar I would guess that everything will work normally, but only 12v will get fed to the motors (or possibly a little less)
Is this correct? or is there something that would detect the low voltage?
I’m thinking in terms of test setups, not running systems.
for that matter, what if you tried to feed it something higher than 24v? are there components that are only rated up to 24v?
The board should work totally fine at 12v.
The stepper motor drivers are only rated to 24 volts so we can’t go any higher than 24 volts :confused:
