I didn’t enter into the config as I was following the youtube video and entering directly into the yaml seemed to cause the previous issue. perhaps the videos are out of date.
when you start the config, one of the things it asks you is what your frame size
is.
That’s used as the initial guess, and the error you are reporting is that that
guess is too far off.
completed successful calibration, fitness 1.069.
entered values into yaml.
uploaded yaml with calibrated values, restarted machine, retracted, extended, applied tension,
[MSG:INFO: Center point deviation: TL: -0.000 TR: 0.104 BL: 0.137 BR: -5.840]
[MSG:INFO: Center point deviation within 15.000mm, your coordinate system is accurate]
now I try to jog and instead of moving, it unspooled some and just unlocked all the motors
no error message or indication that anything is wrong:
When you calibrated, was there a bit in the router and was the z as low as it would go? It’s not in the instructions (and likely should be added to them) that before calibrating you need to remove any bits from the router and drop the z axis all the way down. Often that can cause spooling issues as it tries compensating for an incorrect z position. That being said, I don’t think that usually prevents things from moving entirely.
no bits in the router and it is all the way down,
It simply unspools some and the motors are then unlocked.
I can reapply tension and it gives another correct coordinate system in the serial message
go to jog and same issue
moving the Z axis also just unspools the xy axis belts
Jog: X-5 // unspooled. then I applied tension
[MSG:INFO: Center point deviation: TL: 0.236 TR: 0.091 BL: -0.115 BR: -5.690]
Jog: Z5 // unspooled.
Jog: Z5 // unspooled. then I applied tension
[MSG:INFO: Center point deviation: TL: 0.247 TR: 0.155 BL: -0.053 BR: -4.756]
The unspooling is odd, especially for a z axis move.
It’s like it tells the xy axis motors to turn instead of the z axis
I’ve run out of posts so I’ll have to keep editing this one
I’v solved the calibration issue and followed those steps you lay out in future posts regarding calibration.
The inputs options are under ‘Config’. It asks you for the Width (x-axis dimensions) and Height (y-axis dimensions) of your frame. Changing them using the Config options will change them in the yaml file without needing to edit anything in the yaml file. I would avoid editing anything in the yaml file directly until after things are up and running smoothly.
Also in Config, it asks for home many points in the calibration grid and for the size of the calibration grid. I suggest starting with something like 3x3 or 5x5 grid. After a successful calibration, the system will update the frame dimensions with the dimensions that it calculates from the calibration. At that point, you can start another calibration with more points in the grid (e.g., 7x7 or 9x9).
The calibration should take more points than just that first point.
The process for calibration should be something like this:
Lower z-axis all the way down until you hearing the stepper motors clicking.
Click into the “Config” settings.
In Config: (i) Input the size of your frame into the “Width” and “Height” settings. (ii) Set the calibration grid size to something like 3x3 or 5x5. (iii) Set the calibration grid dimensions to something like 1000x500 (if the grid dimensions are too large, you’ll get an error immediately telling you to reduce them).
Click to save the Config settings.
Retract all belts.
Extend belts out. (This step must be done after changing the Config settings since the settings in Config will tell the machine how much to unspool so that the belts will reach the anchor points on your frame.)
Click Calibrate.
After a successful calibration, you can increase the amount of grid points and the calibration grid size (do not change the frame dimensions, and just use what is already there) and run another calibration for increased accuracy.
If you get this error, it means that the frame dimensions that were inputted are too far off from the actual dimensions of the frame. In the instructions, it says that you do not need accurate frame dimensions and that calibration will figure them out, but you actually do need the inputted dimensions to be reasonably close (~1" for each axis) to the actual frame dimensions, otherwise this error pops up.
Finally got the Maslow to make a cut, but on second attempt It disconnected, after a minute, then I got the following messages after reconnecting: Maslow does not know belt lengths. Please retract and extend before continuing.
error:152 - Configuration is invalid. Maslow.yaml file may be corrupt. Turning off and back on again can often fix this issue. But if I attempt to retract, I get the same message. Router was plunged into the board, when I did a retract and then release, I tried to adjust the Z access, and all 4 belts retracted significantly even with a small z increment
By default, some browsers will ‘sleep’ a tab when you switch to another one. I ran into a lost connection like you describe before I realized that was happening. I was able to avoid it subsequently by changing a setting for that in the browser. Mentioning this in case you were navigating to other tabs.
You mention doing a retract then release before moving the Z axis. Is this accurate? The release tension should not be pressed after retract all if I understand what you wrote.
