Why does Makerverse 1.1.5 suck so much?
So apologies for my fresh language but I’m sick of these supposed “updates” I can’t set a new work home for the life of me without Makerverse 1.1.3. All I get is a “Command G92 unsupported” and I’m using the latest firmware. Which also sucks btw. It all worked fine with previous versions of both the firmware and makerverse, why did something that worked need to be fixed? I get this is open source which means customer support is fucking non-existent but fuck at least make sure the things that worked in previous versions still work in the new versions without having to re-learn the fucking alphabet.
1.1.5 is an alpha test release I believe. You may go back to 1.1.3 if you prefer. Make sure you uncheck the prerelease option for bleeding edge test software.
