I am just now calibrating and now have a per drawing “Bar’s bolt together frame”.
I expect to want a longer and higher top beam in the near future as I expect to cut a lot of nearly full sheet parts which will need to have fairly accurate, straight edges.
Will a longer beam be beneficial for me?
Would you suggest I go ahead and change the beam now and calibrate once, or later and calibrate again?
Thanks,
Tony
