Will a Dewalt DCW604 fit?
Hello
I’m just starting my Maslow journey… I already have a DCW604 router. It is a 18V XR Brushless 8mm / 1/4" Compact Router. Would this be suitable for the Maslow 4.1?
If yes, would it work out the box or would it require me to make a mounting plate?
many thanks
adam
the maslow arms ride on the body of the router. what is the diameter of the
router body and how long is it.
I belive the maslow is built around a 4" tall body 67mm in diameter.
Yes, it should work, I got one to test and it worked, but the battery is a bit of an issue because that is normally right where the controller board mounts so you would have to customize things a bit.
It’s a brushless motor which is pretty nice and a bit quieter, although it’s still not that quiet.
Basically it’s not a drop in replacement for the DW611, but it should be possible to make it work if you are committed to the idea.
Hi Bar
Many thanks for the response. I’ll try and get it to work, if I can’y i’ll get a 611
regards
Thanks David
I’ll give it a go
