It has been asked before, but following the forum the options tend to change with time.
Simple question, when having design in Fusion 360, exported into dxf, where do I manage the cuts?
What is the easiest interface app or workflow between Fusion360 design and Maslow4 cutting?
Can’t you use the CAM in Fusion?
The “Manufacture” tab.
I use that for everything I cut, and it works great.
I like using KrabzCAM, but if Fushion360 has a CAM option that one is probably more convenient
One easy option:
Import dxf from Fusion into Estlecam
In Estlecam click on the lines and select your tool options
Export .nc file
