~ 18 inch across Mask Sculpture
I’m about to do some experiments of my own. I was looking up Woodfill Filaments on Amazon when I realized, I bet a good amount of Maslow users are unaware of Woodfill. It’s a 3D printable PLA filament that in some cases has actual wood fibers and smells of burning wood, some is a foam that looks like wood. The point of Woodfill is once printed it behaves much like wood. It can be sanded, painted, stained, glued and screwed. This opens up a wide range of applications for couplers and fasteners for custom installs.
There are some Woodfill manufacturers that suggest variations in temperature hot enough to discolor the wood fibers can give a real wood grain effect.
Some suggest you should use a larger diameter nozzle such as a .06 mm over a standard .04 mm nozzle. However many report no problems using there .04 nozzle.
If you have a 3D printer you might give it a try. I’m told Hatchbox makes a good Woodfill Filament. Currently it’s on Amazon with same day shipping for Prime Members.
