This isn’t really a problem but I was curious as to why it happens. its only happened a couple times but when I’ve went to raise the z axis it moves the whole sled up the board. does anyone know why this happens? I don’t really need a solution cause like I said it doesn’t happen often but it just seems weird cause there’s no way I hit the wrong button for it to act like that
This usually happens right after the initial setup. Powering up any of the motors will power up all the motors so if you move the z-axis the left and right motors might also make some adjustments if they need to. Right after the initial setup the sled tends to want to move a little bit to get to the center so you might see some movement there.
ah,that makes more sense. thanks!
