I cut the wires to give myself some extra, I wonder if you have accidentally bridged something?
Potentially, but I even went back and took all the solder off the top and cleaned it and then resoldered everything on because I was worried about that. Do you by chance know how to take the PCB off so that I could get to the back side? I wonder if solder got in there somehow.
No idea to be honest. I was lazy and didn’t really want to mess with the new motor so I just spliced. Sorry that’s less than helpful =(
No problem, I was hoping it would be as easy as everyone else but typical my luck is just not there haha.
anyone know what the connector is so we dont’ have to take apart the motor and solder it? looks like a mini Jst 6 pin?
I’m pretty sure the mating connector (on the cable) is this, and these are 12" wires with the appropriate pins on the ends. Order 3 12" wires to get the needed 6 pins with wires attached. The female connector (on the motor) are similar to these.
what is the ideal RPM for the z axis motor? Seems like the stock 12.6rpm is too slow. People have reported good things about the 45rpm and 122rpm ones, which is a big difference. Thinking of getting some directly from china. Thinking either the 55rpm one or 77rpm or 100rpm one?
Also the PPR can be set to 3, 7 or 12. What is best. I am assuming from above comments 7 correct?
I finally have the new motor and Z axis moving… Just needs some dust collection now!
Edit: I thought I knew how to embed, I did not. Here is the link again.
I have this same motor and when I connect it up based on the pin out of the Maslow board the motor starts rotating before anytest are run. Of course when I run a test it fails.
Since there are no cables to buy I am having to build my own. My two chain motors control and pass the testing only the Z motor. Also if I connect one of my other motors to the Zaxis control it test and passes so I know its not the maslow board.
Does anyone have a wiring diagram they used based on the maslow controller pin out for M2 motor?
Here’s the wiring I used:
The stock motor and the PowerControl board use this order:
M+ (black), M- (red), 5V (orange or blue), ground (green), encoderA (white), encoderB (yellow).
With the non-stock motors I’ve bought, the wire colors on the motors match the signal names above, it’s the motor connector that sorts them into a different order. These pairs need to be flipped from the connector on the motor: M+ and M- ; 5V and Gnd; EncA and EncB. Match the motor wire colors with the same colors in the stock z cable or with the picture above and the motor should turn in the same direction as the stock motor.
So I get this error the z axis moves once and then it all stops.
and If I wire the motor just like the x and y motors it just sits and runs non stop
If I wire it based on the image you provided the Ardiuno pwr light on the maslow board shuts off and I lose com3 connection.
If I swap the green and black wires I get the error I posted.
Its weird.
The way that @blurfl has shown is correct.
Just out of curiosity are you soldering directly to the back of the motor or are you soldering the 2 wires together? I am not sure if it was my user error, the motor error or an encoder error with my first unit but it did some strange things to me. I would suggest that you talk with the seller on amazon, I asked for another to be sent to me and it was and I soldered the wires together the second time instead of trying to solder to the back of the motor and it has worked perfectly for me ever since.
No I am soldering to the wires of the motor. LOL getting shorter. I know if I plug one of my other motors into the Zaxis they work based on the harnesses I made for them. so I wired this one exactly the same and motor just runs no stopping. rrg
Appreciate all the input completely determined to figure it out
I would say if another motor works with the harness it is not that. My guess would be the encoder/motor itself. I would suggest a new one (if you ordered from amazon, talk to the seller and ask for a new one they should send it to you). I was driving myself insane when mine wasn’t working and a new motor fixed everything and was totally plug and play the second time. There was so much frustration.
