I wanted to share the progress on my metal frame for the Maslow. I don’t have my kit yet, but trying to be prepared for when it arrives.
Construction is 1-1/2" 16ga box section steel, mig welded together. The frame has a 14’ top beam, with 30" of separation between the beam and the work piece. I put supports in for a 1’ skirt around the work piece if needed. I just have the basic frame done so far:
I had some help cleaning up the mess after clearing that corner of the garage for the frame Most of the projects I want to do with the maslow will be things for them.
The pictures don’t show it well, but there is a 3" spacer between two 14’ pieces of box. From looking at the different frames, that seemed to be the common spacing. If i need to move it out further at some point, i will, but I figured that was a good starting point
this looks like the set up i am about to take on. i currently have a regular maslow set up and i wanted to make one that was capable of cutting edge to edge. these were the numbers i came up with as well. have you finished this set up yet and or had any success with it?
