I do have a question while I plan all my projects though. I havn’t seen any contour projects posted anywhere. Is it even possible to do 3d toolpaths with the maslow/ground control (I really hope so), if not will the feature be added? Also I am planning to add some gearing to the z axis because it looks waaay too slow. If i do so will I be able to calibrate the software/firmware (steps) to reflect my new configuration?
you can do 3D toolpaths, but remember that the sled rides on the surface of the
workpiece, so if you cut off too much of the surface, the sled will dip down.
so the maslow can do 3D inlays into the wood, but it’s not suitable for doing a
3D map (unless you figure out how to keep the sled supported)
Thank you for the replies! I was thinking on a scale smaller than the sled anyway so that shouldn’t be a concern, alternatively a person could leave islands uncarved in the design for the sled to ride on and manually clean them up post processing.
How about the second question of recalibrating steps for the z axis?
