So I have started my first project and it made me wonder if there can be a way to modify the design so that the sled does not have to ride on the cutting surface. This would eliminate the need for an equal thickness border around the perimeter of a project, allow for easier cutting of uneven surfaces (reclaimed wood, etc), and allow for unlimited wells and contouring.
I came up with a simple solution that should not require any tweeking of the software and wanted to run it by the community to see of it is feesable. I am attaching a hand drawing that hopefully makes sense. Please let me know what you think and if you need clarification. Basically I would use two verticle struts that would be a little longer than the work surface. The struts would have wheels at the top and bottom that would allow the struts to glide on a track over the work surface(x axis). The sled would ride in a channel between the struts to allow for y axis movement.
I know, a newb thinking he is going to change the world, but I think it may work. I may try and implement it if you agree. 20190318_173133|575x500
