Another left motor gear failure, need a solution
I looked at the speed specs at git and highlighted the closest to the speed referenced on git. There could be a typo in the speed r/min 17.6 Etonm and 18.6 on git.
it’s been noted before that our motors don’t quite match those specs. The gear
ratio is incorrect and those motors don’t have encoders. The motors we are using
were a custom order, and Bar has listed the specs as 30 Kg/cm.
that page also lists max current (at rated load) as < 1.5A, but we’ve seen
people burn out the 2A rated chips.
We don’t know what the actual motor performance is. It may be worth trying to
test some of the motors.
That test sounds like a good idea, but the weakest link needs to survive in tact for it to be valid. That means lowest common denominator hardware. If the test bends thin motor mounts, its a fail.
As the problems have been left motor, It would be interesting to see if it helps to mount the motor in the same orientation as the right.
____O ____O
instead of
O ____O
Also, for completeness, since the sprocket radius is slightly larger than 1 cm, the rated load capacity is actually 2 lbs less than estimated for 30kg cm at 64lb. If @ManOfScience is correct in his 60lb estimate, that difference matters because we are right near the edge.
The table I copied was from alibaba and it’s mentioned ‘contact supplier’ and ‘custom build’ so the table could be seen as a rough reference. The gear ratio seemed to be an estimate as mentioned in this post Whats inside the gearbox/motor? so the max torque could be one too. I know it’s not an accurate approach, but the best I can do to get an estimate on the stall torque.
I will do it with both shields tonight.
I had a conversation via skype and Etomn did confirm the Maslow motors are custom at 30kg and are not listed on their web site. Not sure why this motor was made custom when the 50kg version on their web site seems like it would work fine. see attached photo.
one reason I don’t think it’s the ‘pull tight’ that’s ruining the gears is that the damage to the gear is spread across too many teeth
This example shows the wear pretty uniformly around the entire gear. Other pictures have shown 1/4 to 1/3 of the teeth damaged.
If this was happening at pull tight, the damage would be far more localized, as you only have a few teeth that mesh with the next gear
I agree. I think that when we’re seeing all the teeth gone in one spot it’s because once it starts slipping one spot gets really worn down. I think that this gear simply needs to be made stronger from the factory to improve the life of the motor. It’s a weak spot right now.
Is this gear the one that replacements are available for?
Yes it is
Edit: Do you want some for testing? I’m happy to send them to you
Hannah mailed some just this week! Thanks for the offer, your support is very, very good :100:
can you send a few to either me or @bee for testing?
Don’t know how many @Bar has, but @Metalmaslow, if you post these for sale In the Market, I would guess that 200 is WAY too few to order
Personally - if I had a place to order some, and they were as cheap as you said, I would want 10 of them to have for repairs into the future. It only takes 20 jerks like me and you’re out of stock.
If anyone is getting ETONM to send more, I think they should ask for 1000 , or more (cash-flow permitting).
Please tell me if this works … I have resin and silicone available and will make a huge batch haha
Also … Im really sorry for my delay … dog is finally out of the scary part and were on the mend. I’ll be back to work at some point this week and will post those 3d files… finally
ummmm … do you think I could get a couple of the gears? My maslows been sitting here dead for almost 2 weeks because of the gear
I am far from an expert and have only been briefly following this, but if the motor plastic gears are wearing (to one degree or another), wont this effect our sled’s “actual” vs computer calculated positions (causing inaccurate/inconsistent cuts)?
It seams to me that if the gears are wearing (deforming), that the sled’s position “tracking” method is being compromised (almost akin to the chains having been stretched).
Are “metal” or other stronger plastic replacement gears available?
it’s not the plastic gear that is wearing out, typically it is a metal one. Gears tend to work pretty good until a complete failure. takes 1 minute to unscrew the 4 screws and check inside if you are really concerned
If that be the case, maybe the gears needs to be made from a better strength steel (hardened?).
Or maybe we need more stiff drive axles…
To me, the wear marks from @Red_Peter’s photo seem to indicate disengagement of the gears,
That could happen if the gear shaft were flexing from too much weight being far out from the support bushing/bearing causing the axle to flex the gears apart:
I don’t know how we would check for this though.
I’m sorry to hear about the Dog being in a bad position, my dog is my family.
On the mend is good.
No. The gear wear primarily affects backlash. And by design, backlash isn’t an issue for Maslow. Total chain length is increased by a tiny amount, but that amount is consistent everywhere. Your center point will shift a little, but your shapes will all be correct. Unless of course the gears actually start slipping; in that case, the error is unpredictable and potentially very large.
