Hi Everyone,
I am pretty new to Maslow 4. I set it up yesterday on a homemade, somewhat collapsible frame. I say this in case it is possible that the lack of frame rigidity may have contributed to the problem. I started a long CNC session yesterday with gcode made by Cambam. The cuts began with several pocket operations followed by inner profile operations followed by outer profiles. At one point during the final outer profile operations, it stopped and I was unable to retrieve the serial code. The cuts were going at a feedrate of 30 inches per minute. Today, I tried redoing cuts that it missed. This time at 40 inches per minute feedrate. This involved pockets and outer profile cuts. It did the pockets successfully and started the profile. This is how it looked:
This time, I captured the serial data. It is as follows:
Serial Messages
Index.html Version: 0.82
[MSG:INFO: FluidNC v0.81 (Maslow-Main-b6772b63-dirty)]
[MSG:INFO: Board Maslow]
[MSG:INFO: Axis count 3]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor0]
[MSG:INFO: Motor1]
[MSG:INFO: Connecting to STA SSID:ModianoNet]
[MSG:INFO: Connecting.]
[MSG:INFO: Connecting…]
[MSG:INFO: Connected - IP is 192.168.68.114]
[MSG:INFO: WiFi on]
[MSG:INFO: SSDP Started]
Home pos set for: Z
[G54:750.000,-550.000,31.060]
Home pos set for: X
Home pos set for: Y
[G54:750.000,-500.000,31.060]
[MSG:INFO: Tool No: 1]
[MSG:WARN: Encoder read failure on Top Left]
[MSG:WARN: Bad connection on Top Left encoder, failed to read 3 times in the last second]
[MSG:WARN: Bad connection on Top Left encoder, failed to read 7 times in the last second]
[MSG:WARN: Bad connection on Top Left encoder, failed to read 2 times in the last second]
[MSG:WARN: Bad connection on Top Left encoder, failed to read 1 times in the last second]
[MSG:WARN: Bad connection on Top Left encoder, failed to read 5 times in the last second]
[MSG:WARN: Bad connection on Top Left encoder, failed to read 17 times in the last second]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 32.042mm Counter: 1]
[MSG:WARN: Previous error was 32.042mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 32.030mm Counter: 2]
[MSG:WARN: Previous error was 32.030mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 32.012mm Counter: 3]
[MSG:WARN: Previous error was 32.012mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 31.994mm Counter: 4]
[MSG:WARN: Previous error was 31.994mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 31.976mm Counter: 5]
[MSG:WARN: Previous error was 31.976mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 16.545mm Counter: 1]
[MSG:WARN: Previous error was 16.545mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 16.533mm Counter: 2]
[MSG:WARN: Previous error was 16.533mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 16.515mm Counter: 3]
[MSG:WARN: Previous error was 16.515mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 16.496mm Counter: 4]
[MSG:WARN: Previous error was 16.496mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 16.472mm Counter: 5]
[MSG:WARN: Previous error was 16.472mm]
[MSG:WARN: Position error on Bottom Right axis exceeded 15mm while running. Error is 16.454mm Counter: 6]
[MSG:WARN: Previous error was 16.454mm]
[MSG:INFO: Reset during file job at line: 1360]
[MSG:ERR: Position error > 15mm while running. E-Stop triggered.]
Yesterday’s cut went for much longer before it failed. Might it have been the more aggressive feedrate? If any of you with more experience can tell me what these errors that led to the end of these jobs (and the sad waste of time and plywood), I would appreciate your guidance.
Thanks,
Paul,
