these tiny trailers can be pulled by anything (they have 10-12" wheels)
I donāt think you can pull a 43 foot travel trailer with slideouts but it should be good enough for an Imprezaās 1000 or so pounds. Check your owners manual.
https://www.etrailer.com/vehicle-finder.aspx?passmake=Subaru&passmodel=Impreza&hhcat=hitch
The manual has a big warning before the towing section saying āNot recommended for towingā, but later it does say that it could handle ~1000 lbs. Iām a little surprised. Itās not exactly a powerful vehicle.
Iāll have to take our 4x9 to a weight station at some point. If I could pull it and a couple of sheets of plywood that would make my life infinitely easier.
I previously had a Chevy Cruze 1.4, a smaller and less powerful car that your Impreza, and towed with it. It had a 1,000 pound rating, so I would frequently pull trailers up to about 700-800 pounds, in some cases for hundreds of miles. Didnāt go crazy with speed or anything, but it always got me there!
If it looks like you could weigh one wheel at a time on a bathroom scale then you should be good to go. Is the weight on your registration?
Iāve pulled a ton of wood pellets with my 1000# rated Vibe, slow and easy. Those ratings are worst case, uphill on a potholed freeway. Of course, this isnāt a recommendation or advised per my attorneys Dewey, Cheatum, and Howe (of Cartalk fame)
Aww man! You mean I should be street racing AND towing my sheet goods at the same time?
Itās a home-made craigslist find, so I donāt have any of documentation on it. Good idea with the bathroom scales though! Itās a bit overbuilt for itās size, which is the reason Iām wary of the empty weight. Itās probably fine, Iām guessing it somewhere between 600-800 lbs. Still leaves enough payload capacity for a few sheets of plywood.
In my case, even if I tried a fit cyclist could probably still have outrun me.
Limit it to autocross and you should be OK. Although we did tear a Fiero 4 cyl off itās mounts onceā¦
You guys must have been really giving that Fiero a real hot supper! Iād love to have a Fiero project at some point, Those are fun cars
I should do some autocross soon! Itās wicked fun and way less dangerous than all the street racing I used to do.
