Would it be possible to add a kind of auto-translate on the forum, but just to convert between metric and imperial.
Don’t know if it’s feasable, but you guys seem to find a new function to add to the forum every other week, and it doesn’t seem to far fetched.
It would make the forums a lot more readable for us with the practical units of measurement. I know how much an inch is, but i don’t feel it, if you say 15cm, i can see it in my mind, 6 inches is not that easy to visualise.
Giggle takes max 15 seconds to convert.
If I have time I post both, first metric, then imperial. A sign of respect.
If I don’t have time I just post metric.
A Forum function is from my knowledge to pre-built-in.
one problem with auto-conversions is that they tend to imply more precision is
needed than there really is.
If I say 10 inches, 254mm is the exact conversion, but really, “about 25cm” is
the right way to think about it.
I prefer exact numbers.
25 mm is 0.98 inches. not 1.
Check it Сonvert millimeter to inch
All of which reminded me of Imperial Measurements Explained ![]()
!!! (youtube.com)
not sure automatic conversion works for woodworking.
the equivalent of a 2x4” (50,8x101,6mm) is actually an 39x89mm SLS.
the equivalent of 3/4” (19,06mm) plywood is 18mm plywood.
a lot of 3/4" plywood is 18mm
woodworking is not machining, and especially if you are buying stock, having it
vary by several mm in not unusual
