Here is a quick little project for use in the house. I had a left over piece of 3/4" plywood from the camper cut out and wanted to put it to good use. What’s that saying, “Happy Wife, Happy Life”.
The stool can be cut out of 15" x 25" stock with a generous margin of 1" on all sides.
I did run into an accuracy issue, probably because I can’t seem to get a good fitness score. The requested pockets were supposed to be 0.75" (19.05mm) wide and they measured 0.6955"(17.6657mm) so 0.0545"(1.38mm) off. 1.38mm error across 19.05mm is less than desirable.
Either way I setup a contour toolpath with a -0.027 in radial stock to leave to fix the error.
Now my daughter and I have something to do tonight involving paint.
File ran to do the main cutting.
Bathroom Potty Training Stool.nc (61.6 KB)
Fusion file.
Bathroom Potty Training Stool v4.f3d (831.0 KB)
