Belts become loose on any axis movement
Hi, some news:
I found a post where the following maslow.yaml-lines were described:
Maslow_tlZ: 100.000000
Maslow_trZ: 56.000000
Maslow_blZ: 34.000000
Maslow_brZ: 78.000000
They are about the z-distance from the ancor to the sled. I found out, there are 19mm for the plywood.
My ancors are at the same z-level as the sled, so I go 20mm down:
Maslow_tlZ: 80.000000
Maslow_trZ: 36.000000
Maslow_blZ: 14.000000
Maslow_brZ: 58.000000
I although set the retraction force to 2000 (I know, that´s a bit tough).
And now it´s working! All belts are tight when jogging. I will write again after the first cut!
Glad it seems to be working; however, +/-5mm on tensioning is a very large amount. I didn’t have this issue but from research it points to the encoders not accurately reading the belt movement. It should be sub 1mm ideally. This could be caused by magnets that aren’t glued down in the encoder arm, or potentially encoder cables that are intermittently losing connection. I solved a lot of issues with glued down cables, and switching to the JST kit soon.
Someone else can chime in as well, but the machine is set to flag anything outside of 15mm from what it expects, so it will go on with any cable deviation under that which will still cause some issues. I’d imagine inaccurate encoder readings while calibrating will also screw things up.
I’m seeing the same issues with JST running .79 version. I’m attempting again but it seems the bottom right belt is a bit more slack than others and when plotting a straight line it sort of bounces. And center point deviation is also about 8mm for the bottom right on start up. (I rand multiple calibrations.)
Update:
I recalibrate with .84 and center point deviation was 6mm for bottom right.
I opened we up to check the magnet on bottom right to see if our of place or spinning. All looked good.
Put it back together and swapped the BR motor and the TR motor. To see if it is a bad motor. Outcome was the same after running calibration. Infact it does this little bounce during calibration.
I’m at a loss. After calibration I was seeing center point dev for BR is 3.7 and BL -3.13
Any ideas? I’m really at a loss.
Is there any twist in your frame? Also, what do your corner anchors look like? Any flex in the anchors can really screw up the calibration.
No. Frame is set to about 22 degrees vert. And very uniform all around with solid anchor points.
No bend in them .
I was cutting alright (only small dips on initial jogs)prior to the upgrade JST with .84
All seems to have really changed once I swapped to the JST.
Im about to sit down right now and swap back. Although I loath that bc of stripping and the tedium , but I can’t think of much else.
Sigh.
I’m 100% certain that this is not a JST related issue, I wouldn’t go through the trouble of switching back.
Do you have your old .yaml file? The switch to the new encoder boards shouldn’t require re-calibrating even.
I have an idea. The BR is loose because either…
  1. the motor / idler is too tight against the spool, causing too much friction and the belt is not retracting smoothly - or
  2. you could have an issue with the gear rubbing an unseated bearing (here: All belts retracting but one - #4 by gazinux)
(Is it possible the problem appeared when you put the new encoders on because you might’ve tightened the motor up too snug against the idler?)
You’ll have to take the arm apart either way :expressionless:
Mine did a similar sort of drunken sailor swagger when I had the first issue above.
Good news. It’s fixed! After taking it all apart I found the issue was indeed with the magnets. I had checked this before but must have missed it or got a false positive. Who knows. It’s working now. Glued down well and seated properly.
Though I’m still having some issues with the plunge or even ramp down when initiating a cut. Have you or anyone run into this? I noticed my bottom right belt is not as tight as my others.
That’s great to hear!
As someone who builds cars and motorcycles, I’ve found that if you’re not familiar with working on something, you’re doomed to repeat the job until you get it right! I’m now a pro at dismantling the Maslow for that exact reason. This time the set screw from a gear popped out and I won’t forget to make sure they are tight now. So it goes.
Gosh isn’t that the truth with any maintenance.
This is a very timely reminder on top of reminders I should know well by now. I’m re reading “Zen and the art of motorcycle maintenance”. Can’t recommend enough for many reasons.
Cheers!
Love that book!
