Best method to align spoilboard perfectly?
What is the recommended way of getting the spoilboard perfectly aligned with the Maslow?
I’m hoping to cut triangular shapes out of rigid foam board and use the edge of the 4x8 foam board as one of the edges of the triangle. This would mean less cutting time.
If I have the 4x8 spoilboard perfectly aligned then I can place the foam on top and start the cutting.
Or is using the edge unrealistic and I should plan on cutting all three sides within the 4x8 sheet? Even if I go this route I would need the spoilboard pretty close to perfect if I’m to get efficient use of my material.
Triangle edge lengths: 46”, 46”, 52”
Thanks for any tips!
I have a height adjustable extension (150mm wide) about 30mm from the edge of the spoil board, which I can set to the same height as the work piece. It allows the Maslow to be supported when it goes beyond the work piece so i can cut right to the edge.
Thanks for the quick reply and extension suggestion; I’ll difinately need that. But how do you align the maslow work area ( green box ) with your material?
The Bottom Left is defined as blX=0 and blY=0 and Bottom Right as brX=x and brY=0 where x is defined as the right anchor point as found by Find Anchor points. This means the bottom of the spoil board should be parallel with the BL-BR line.
If you jog your Maslow down to the bottom left on the spoil board and set the XY home to this position it should let you orient anything you want to cut from this position. To check, jog the Maslow to the right to confirm it stays online across the spoil board. Does this make sense?
use the maslow to cut a slot across the bottom of your spoilboard and then put a
board in that to align your foam.
Thanks; that makes sense. Trying that now… running into other issue. Creating separate posts for those.
@ian_ab how does your height adjuster work?
We recently added a “Trace Boundary” button to the UI which is really helpful for that.
Basically it will move the machine around all of the parts in the currently opened gcode file to check that they will fit on the sheet.
The button won’t open until you have a gcode file opened.
For cutting triangles out of a sheet you might find that something like a track saw is a really fast and easy way to do that
I was using the track saw.. also was using a heat knife… but it was slow to trace the shapes onto the foam, and labor intensive to do the cuts. This cnc idea was supposed to be the quick efficient thing.
It is sounding like getting the exact edges of the boundary synced with the job would not be accurate enough to use the stock edges of the plywood/foam. I guess this isn’t too big of a deal; just have to wait for the extra cutting time to cut the entire shape from inside the material.
Trace Boundary will be helpful to make sure I’m within bounds.
Thank you.
guess this isn¢t too big of a deal; just have to wait for the extra cutting
what is wrong with the idea of cutting a reference line and aligning the foam
with that line?
Yes; I was planning to try that but it all crashed and I had to recalibrate… I set it up last night and it wasn’t done as of 5 min ago. So I’m gonna try to calibrate again now.
you don’t need to calibrate after a crash, once you get a good set of anchor
locations you just need to retract/extend/apply tension.
Good to know. If I’ve started a new calibration that hasn’t finished; then it should still be calibrated with previous calibration? Just need to cancel current calibration and R.E.A.T?
ok; cancelled the calibration… now it says this:
[MSG:ERR: Center point deviation over 12.000mm, your coordinate system is not accurate, maybe try running calibration again?]
Also; is this a “maybe try” or “definitely try because there is no other choice” situation?
Wes wrote:
Good to know. If I¢ve started a new calibration that hasn¢t finished; then it
unfortunantly no, each step of calibration saves it’s results before starting
the next round of measurements.
but if you have a copy of your old maslow.yaml, you can just revert to it.
Unless you have a prior version of the maslow.yaml saved (to give you the
results of the last calibration), you will need to re-run calibration.
But you’ve been posting here a lot, so it seems that you should have a prior
result somewhere.
Forgot to save it ( actually didn’t see how to do it ) … I found how to download it so I will do that after my next good calibration.
If you saved or posted your log, the calibration results will be in the log.
Socket wrench to wind bolt which revolves in upper bracket, nut in 3dprinted holder causes extension to rise or lower, until level with the cutting surface
Cool. Nice set up
