Using the R2200
I’m guessing it was under strain and the screws gave out that connected the motor to the top coupling.
Could this have something to do with that orange button?
Any suggestions on how to prevent this?
Using the R2200
sounds like the router base was too tight and movement up and down too much for the motor. Did you have the clamp loose and the router lubed up as recommended?
Disclaimer: I have a ryobi router (the rigid’s plastic cousin that has the same lead screw and base design) so my experience is limited, but I did use it before I switched it for a different router for a few reasons, one if which was the bungee. I also read most of what is posted on this forum and while I don’t have a link off hand, if you search “router lube” or z axis, you will find an afternoon’s worth of reading. The thing to note is that the base was designed to clamp and hold the router and not move for typical router operation. The base is being repurposed as a glide sleeve when mounted on the sled, so it has to be ‘reconfigured’ to work appropriately. To summarize, the narrative goes something like:
I think that is it. If your z axis motor is fried or over torqued, the router movement is either too loose and binding by going crooked or too tight and binding. It is like goldilocks… needs to be just right.
Lube the base and loosen the quick-release nut.
Good stuff thank you! I’m ordering a file and some dry lube now.
My Z-Axis motor actually tore itself into 2 pieces. The top most piece where encoder cable attaches separated from the rest of the unit and was dangling by the cord.
be sure to zip tie the cable to the motor or something nearby for strain relief so if the cable gets caught, the zip tie will tear the cable rather than tweak the motor. Is it possible the cable was stressed funny and damaged the motor?
There must be small screws floating around inside the gear box, did they come loose, or strip out somehow?
Edit: wondering if it is salvageable by opening up the gearbox, and using loctite on the screws if it is otherwise serviceable as a spare.
I’m checking the floor and shop vac with a magnet. So far no luck.
these are mass produced by machines, probabaly uses a pounded or twisted metal type connector and not screws. The force was too great on an unlubed 10 lb router and the metal came apart.
