Hi there
Got the kit in 2018 but just started assemly.
The 18 wood screws that should be used to hold the L-Brackets to the sled don’t seem to make sense.
1 - they are too thick to even start going through the holes in the backet
2 - They seems really short at 9.5mm to hold on anything with the backets being 3mm thick.
So my questions:
1 - Did some of you enlarge the holes in the brackets ?
2 - Used different screws?
I’m thinking about 3D-printing a 1 or 2 holes filler-bushing to fill the large center hole and use a larger flat head bolt and nut going through it with a large washer to hold the bracket foot down.
Anyone has a similar issue and found a way around ?
thanks
__
Valafar
Montréal, Canada
