what do you mean by wrong mode? vertical vs horizontal measurements?
This option in the Configuration screen. Should be set to Vertical if the frame is up against a wall at an angle, Horizontal if it is flat on the floor or on a table.
I initially mistakenly thought this was a portrait/landscape thing, so a little confusing.
So, finally got back to it and yes, that was the issue. I had not selected the orientation of the set up.
Than you all for the support.
Now time to try and make it work.
To further characterize what you helped us learn here, when your broke your belts, was your work piece flat and your setting “vertical”, or was your work piece upright and your setting “horizontal”?
