Calibration: Fitness Too Low on .73
It doesn’t look like the change made a difference.
I re-ran the calibration with v .74 using defaults except for the frame size (8x12) and got the same Fitness Too Low message.
I changed the acceptable calibration threshold setting mentioned in release notes to .3, saved, restarted, verified the change was save and re-ran the calibration process. Unfortunately I got the same result even though the fitness lowest fitness level was something like 4.27.
Any other things I can try?
Here are the results:
[MSG:INFO: Zeroing z-axis position]
[MSG:INFO: Center point deviation: TL: 0.083 TR: 0.108 BL: -3.162 BR: -5.874]
CLBM:[{bl:2167.96,   br:2209.71,   tr:2174.06,   tl:2221.87},{bl:2103.59,   br:2149.42,   tr:2243.75,   tl:2289.64},{bl:1894.65,   br:2364.00,   tr:2447.95,   tl:2096.19},{bl:1967.01,   br:2423.19,   tr:2384.94,   tl:2018.14},{bl:2047.27,   br:2488.72,   tr:2323.51,   tl:1945.00},{bl:2241.28,   br:2286.83,   tr:2106.47,   tl:2151.82},{bl:2444.80,   br:2089.89,   tr:1897.51,   tl:2370.13},{bl:2382.14,   br:2011.83,   tr:1970.07,   tl:2430.09},{bl:2320.65,   br:1938.67,   tr:2048.59,   tl:2494.40},]
Computing... This may take several minutesFitness: 1.8197615 in 100
Fitness: 1.8197615 in 200
Fitness: 1.8197615 in 300
Fitness: 1.8197615 in 400
Fitness: 1.8197615 in 500
Fitness: 1.8197615 in 600
Fitness: 1.8197615 in 700
Fitness: 1.8197615 in 800
Fitness: 1.8197615 in 900
Fitness: 1.8197615 in 1000
Calibration complete
Calibration values:
Fitness: 1.8197613710518914
Maslow_tlX: -58.7
Maslow_tlY: 2441.0
Maslow_trX: 3592.8
Maslow_trY: 2439.4
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3641.9
Maslow_brY: 0.0
These values have been automatically saved for you.
[MSG:INFO: Measured waypoint 9]
[MSG:INFO: Measured waypoint 10]
[MSG:INFO: Measured waypoint 11]
[MSG:INFO: Measured waypoint 12]
[MSG:INFO: Measured waypoint 13]
[MSG:INFO: Measured waypoint 14]
[MSG:INFO: Measured waypoint 15]
[MSG:INFO: Measured waypoint 16]
[MSG:INFO: Measured waypoint 17]
[MSG:INFO: Measured waypoint 18]
[MSG:INFO: Measured waypoint 19]
[MSG:INFO: Measured waypoint 20]
[MSG:INFO: Measured waypoint 21]
[MSG:INFO: Measured waypoint 22]
[MSG:INFO: Measured waypoint 23]
[MSG:INFO: Measured waypoint 24]
CLBM:[{bl:2167.96,   br:2209.71,   tr:2174.06,   tl:2221.87},{bl:2103.59,   br:2149.42,   tr:2243.75,   tl:2289.64},{bl:1894.65,   br:2364.00,   tr:2447.95,   tl:2096.19},{bl:1967.01,   br:2423.19,   tr:2384.94,   tl:2018.14},{bl:2047.27,   br:2488.72,   tr:2323.51,   tl:1945.00},{bl:2241.28,   br:2286.83,   tr:2106.47,   tl:2151.82},{bl:2444.80,   br:2089.89,   tr:1897.51,   tl:2370.13},{bl:2382.14,   br:2011.83,   tr:1970.07,   tl:2430.09},{bl:2320.65,   br:1938.67,   tr:2048.59,   tl:2494.40},{bl:2262.65,   br:1869.75,   tr:2136.88,   tl:2565.83},{bl:2039.67,   br:2085.76,   tr:2322.56,   tl:2369.25},{bl:1823.58,   br:2310.70,   tr:2520.62,   tl:2179.25},{bl:1617.25,   br:2541.35,   tr:2727.81,   tl:2002.47},{bl:1696.65,   br:2587.62,   tr:2663.85,   tl:1912.45},{bl:1780.75,   br:2641.22,   tr:2602.94,   tl:1826.56},{bl:1867.11,   br:2702.12,   tr:2546.72,   tl:1745.37},{bl:1959.30,   br:2764.63,   tr:2495.47,   tl:1669.67},{bl:2130.27,   br:2561.47,   tr:2267.51,   tl:1878.70},{bl:2318.48,   br:2361.12,   tr:2044.44,   tl:2093.64},{bl:2515.97,   br:2171.14,   tr:1828.40,   tl:2317.39},{bl:2722.20,   br:1994.43,   tr:1622.29,   tl:2544.63},{bl:2659.21,   br:1904.29,   tr:1703.43,   tl:2592.91},{bl:2598.32,   br:1818.43,   tr:1784.96,   tl:2648.51},{bl:2542.08,   br:1737.05,   tr:1871.71,   tl:2708.56},{bl:2490.88,   br:1661.25,   tr:1963.11,   tl:2772.27},]
Computing... This may take several minutesFitness: 0.8283103 in 100
Fitness: 0.8283103 in 200
Fitness: 0.8283103 in 300
Fitness: 0.8283103 in 400
Fitness: 0.8283103 in 500
Fitness: 0.8283103 in 600
Fitness: 0.8283103 in 700
Fitness: 0.8283103 in 800
Fitness: 0.8283103 in 900
Fitness: 0.8283103 in 1000
Calibration values:
Fitness: 0.8283102528822919
Maslow_tlX: -58.1
Maslow_tlY: 2441.0
Maslow_trX: 3593.7
Maslow_trY: 2439.8
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3643.1
Maslow_brY: 0.0
[MSG:INFO: Measured waypoint 25]
[MSG:INFO: Measured waypoint 26]
[MSG:INFO: Measured waypoint 27]
[MSG:INFO: Measured waypoint 28]
[MSG:INFO: Measured waypoint 29]
[MSG:INFO: Measured waypoint 30]
[MSG:INFO: Measured waypoint 31]
[MSG:INFO: Measured waypoint 32]
[MSG:INFO: Measured waypoint 33]
[MSG:INFO: Measured waypoint 34]
[MSG:INFO: Measured waypoint 35]
[MSG:INFO: Measured waypoint 36]
[MSG:INFO: Measured waypoint 37]
[MSG:INFO: Measured waypoint 38]
[MSG:INFO: Measured waypoint 39]
[MSG:INFO: Measured waypoint 40]
[MSG:INFO: Measured waypoint 41]
[MSG:INFO: Measured waypoint 42]
[MSG:INFO: Measured waypoint 43]
[MSG:INFO: Measured waypoint 44]
[MSG:INFO: Measured waypoint 45]
[MSG:INFO: Measured waypoint 46]
[MSG:INFO: Measured waypoint 47]
[MSG:INFO: Measured waypoint 48]
CLBM:[{bl:2167.96,   br:2209.71,   tr:2174.06,   tl:2221.87},{bl:2103.59,   br:2149.42,   tr:2243.75,   tl:2289.64},{bl:1894.65,   br:2364.00,   tr:2447.95,   tl:2096.19},{bl:1967.01,   br:2423.19,   tr:2384.94,   tl:2018.14},{bl:2047.27,   br:2488.72,   tr:2323.51,   tl:1945.00},{bl:2241.28,   br:2286.83,   tr:2106.47,   tl:2151.82},{bl:2444.80,   br:2089.89,   tr:1897.51,   tl:2370.13},{bl:2382.14,   br:2011.83,   tr:1970.07,   tl:2430.09},{bl:2320.65,   br:1938.67,   tr:2048.59,   tl:2494.40},{bl:2262.65,   br:1869.75,   tr:2136.88,   tl:2565.83},{bl:2039.67,   br:2085.76,   tr:2322.56,   tl:2369.25},{bl:1823.58,   br:2310.70,   tr:2520.62,   tl:2179.25},{bl:1617.25,   br:2541.35,   tr:2727.81,   tl:2002.47},{bl:1696.65,   br:2587.62,   tr:2663.85,   tl:1912.45},{bl:1780.75,   br:2641.22,   tr:2602.94,   tl:1826.56},{bl:1867.11,   br:2702.12,   tr:2546.72,   tl:1745.37},{bl:1959.30,   br:2764.63,   tr:2495.47,   tl:1669.67},{bl:2130.27,   br:2561.47,   tr:2267.51,   tl:1878.70},{bl:2318.48,   br:2361.12,   tr:2044.44,   tl:2093.64},{bl:2515.97,   br:2171.14,   tr:1828.40,   tl:2317.39},{bl:2722.20,   br:1994.43,   tr:1622.29,   tl:2544.63},{bl:2659.21,   br:1904.29,   tr:1703.43,   tl:2592.91},{bl:2598.32,   br:1818.43,   tr:1784.96,   tl:2648.51},{bl:2542.08,   br:1737.05,   tr:1871.71,   tl:2708.56},{bl:2490.88,   br:1661.25,   tr:1963.11,   tl:2772.27},{bl:2445.61,   br:1592.35,   tr:2053.86,   tl:2840.05},{bl:2212.69,   br:1809.86,   tr:2221.84,   tl:2642.89},{bl:1984.05,   br:2033.79,   tr:2399.46,   tl:2448.61},{bl:1760.93,   br:2264.32,   tr:2594.84,   tl:2265.29},{bl:1546.29,   br:2496.72,   tr:2794.68,   tl:2095.81},{bl:1343.84,   br:2732.64,   tr:3003.80,   tl:1943.86},{bl:1429.24,   br:2769.57,   tr:2943.15,   tl:1842.51},{bl:1516.11,   br:2815.13,   tr:2882.72,   tl:1744.32},{bl:1608.24,   br:2864.82,   tr:2826.50,   tl:1649.70},{bl:1705.08,   br:2920.41,   tr:2774.80,   tl:1559.32},{bl:1804.81,   br:2982.21,   tr:2727.87,   tl:1474.06},{bl:1907.64,   br:3042.22,   tr:2685.89,   tl:1394.78},{bl:2051.62,   br:2838.82,   tr:2450.07,   tl:1598.53},{bl:2217.11,   br:2635.80,   tr:2217.26,   tl:1815.89},{bl:2399.11,   br:2441.50,   tr:1988.57,   tl:2038.74},{bl:2590.63,   br:2258.19,   tr:1765.63,   tl:2267.80},{bl:2791.33,   br:2088.77,   tr:1551.08,   tl:2499.27},{bl:2998.73,   br:1936.98,   tr:1348.71,   tl:2732.23},{bl:2938.72,   br:1835.47,   tr:1433.23,   tl:2772.42},{bl:2878.30,   br:1737.12,   tr:1519.91,   tl:2818.74},{bl:2822.10,   br:1642.34,   tr:1610.71,   tl:2870.02},{bl:2770.42,   br:1551.86,   tr:1707.34,   tl:2925.57},{bl:2723.51,   br:1466.51,   tr:1806.16,   tl:2985.88},{bl:2681.57,   br:1387.02,   tr:1910.85,   tl:3049.37},]
Computing... This may take several minutesFitness: 0.5575481 in 100
Fitness: 0.5575481 in 200
Fitness: 0.5575481 in 300
Fitness: 0.5575481 in 400
Fitness: 0.5575481 in 500
Fitness: 0.5575481 in 600
Fitness: 0.5575481 in 700
Fitness: 0.5575481 in 800
Fitness: 0.5575481 in 900
Fitness: 0.5575481 in 1000
Calibration values:
Fitness: 0.5575481085960983
Maslow_tlX: -57.1
Maslow_tlY: 2441.0
Maslow_trX: 3593.7
Maslow_trY: 2440.8
Maslow_blX: 0.0
Maslow_blY: 0.0
Maslow_brX: 3644.4
Maslow_brY: 0.0
[MSG:INFO: Measured waypoint 49]
[MSG:INFO: Measured waypoint 50]
[MSG:INFO: Measured waypoint 51]
[MSG:INFO: Measured waypoint 52]
[MSG:INFO: Measured waypoint 53]
[MSG:INFO: Measured waypoint 54]
[MSG:INFO: Measured waypoint 55]
[MSG:INFO: Measured waypoint 56]
[MSG:INFO: Measured waypoint 57]
[MSG:INFO: Measured waypoint 58]
[MSG:INFO: Measured waypoint 59]
[MSG:INFO: Measured waypoint 60]
[MSG:INFO: Measured waypoint 61]
[MSG:INFO: Measured waypoint 62]
[MSG:INFO: Measured waypoint 63]
[MSG:INFO: Measured waypoint 64]
[MSG:INFO: Measured waypoint 65]
[MSG:INFO: Measured waypoint 66]
[MSG:INFO: Measured waypoint 67]
[MSG:INFO: Measured waypoint 68]
[MSG:INFO: Measured waypoint 69]
[MSG:INFO: Measured waypoint 70]
[MSG:INFO: Measured waypoint 71]
[MSG:INFO: Measured waypoint 72]
[MSG:INFO: Measured waypoint 73]
[MSG:INFO: Measured waypoint 74]
[MSG:INFO: Measured waypoint 75]
[MSG:INFO: Measured waypoint 76]
[MSG:INFO: Measured waypoint 77]
[MSG:INFO: Measured waypoint 78]
[MSG:INFO: Measured waypoint 79]
[MSG:INFO: Measured waypoint 80]
CLBM:[{bl:2167.96,   br:2209.71,   tr:2174.06,   tl:2221.87},{bl:2103.59,   br:2149.42,   tr:2243.75,   tl:2289.64},{bl:1894.65,   br:2364.00,   tr:2447.95,   tl:2096.19},{bl:1967.01,   br:2423.19,   tr:2384.94,   tl:2018.14},{bl:2047.27,   br:2488.72,   tr:2323.51,   tl:1945.00},{bl:2241.28,   br:2286.83,   tr:2106.47,   tl:2151.82},{bl:2444.80,   br:2089.89,   tr:1897.51,   tl:2370.13},{bl:2382.14,   br:2011.83,   tr:1970.07,   tl:2430.09},{bl:2320.65,   br:1938.67,   tr:2048.59,   tl:2494.40},{bl:2262.65,   br:1869.75,   tr:2136.88,   tl:2565.83},{bl:2039.67,   br:2085.76,   tr:2322.56,   tl:2369.25},{bl:1823.58,   br:2310.70,   tr:2520.62,   tl:2179.25},{bl:1617.25,   br:2541.35,   tr:2727.81,   tl:2002.47},{bl:1696.65,   br:2587.62,   tr:2663.85,   tl:1912.45},{bl:1780.75,   br:2641.22,   tr:2602.94,   tl:1826.56},{bl:1867.11,   br:2702.12,   tr:2546.72,   tl:1745.37},{bl:1959.30,   br:2764.63,   tr:2495.47,   tl:1669.67},{bl:2130.27,   br:2561.47,   tr:2267.51,   tl:1878.70},{bl:2318.48,   br:2361.12,   tr:2044.44,   tl:2093.64},{bl:2515.97,   br:2171.14,   tr:1828.40,   tl:2317.39},{bl:2722.20,   br:1994.43,   tr:1622.29,   tl:2544.63},{bl:2659.21,   br:1904.29,   tr:1703.43,   tl:2592.91},{bl:2598.32,   br:1818.43,   tr:1784.96,   tl:2648.51},{bl:2542.08,   br:1737.05,   tr:1871.71,   tl:2708.56},{bl:2490.88,   br:1661.25,   tr:1963.11,   tl:2772.27},{bl:2445.61,   br:1592.35,   tr:2053.86,   tl:2840.05},{bl:2212.69,   br:1809.86,   tr:2221.84,   tl:2642.89},{bl:1984.05,   br:2033.79,   tr:2399.46,   tl:2448.61},{bl:1760.93,   br:2264.32,   tr:2594.84,   tl:2265.29},{bl:1546.29,   br:2496.72,   tr:2794.68,   tl:2095.81},{bl:1343.84,   br:2732.64,   tr:3003.80,   tl:1943.86},{bl:1429.24,   br:2769.57,   tr:2943.15,   tl:1842.51},{bl:1516.11,   br:2815.13,   tr:2882.72,   tl:1744.32},{bl:1608.24,   br:2864.82,   tr:2826.50,   tl:1649.70},{bl:1705.08,   br:2920.41,   tr:2774.80,   tl:1559.32},{bl:1804.81,   br:2982.21,   tr:2727.87,   tl:1474.06},{bl:1907.64,   br:3042.22,   tr:2685.89,   tl:1394.78},{bl:2051.62,   br:2838.82,   tr:2450.07,   tl:1598.53},{bl:2217.11,   br:2635.80,   tr:2217.26,   tl:1815.89},{bl:2399.11,   br:2441.50,   tr:1988.57,   tl:2038.74},{bl:2590.63,   br:2258.19,   tr:1765.63,   tl:2267.80},{bl:2791.33,   br:2088.77,   tr:1551.08,   tl:2499.27},{bl:2998.73,   br:1936.98,   tr:1348.71,   tl:2732.23},{bl:2938.72,   br:1835.47,   tr:1433.23,   tl:2772.42},{bl:2878.30,   br:1737.12,   tr:1519.91,   tl:2818.74},{bl:2822.10,   br:1642.34,   tr:1610.71,   tl:2870.02},{bl:2770.42,   br:1551.86,   tr:1707.34,   tl:2925.57},{bl:2723.51,   br:1466.51,   tr:1806.16,   tl:2985.88},{bl:2681.57,   br:1387.02,   tr:1910.85,   tl:3049.37},{bl:2645.27,   br:1316.18,   tr:2010.46,   tl:3114.85},{bl:2405.84,   br:1531.78,   tr:2147.02,   tl:2916.84},{bl:2168.60,   br:1755.75,   tr:2306.77,   tl:2719.23},{bl:1934.57,   br:1986.10,   tr:2483.13,   tl:2530.90},{bl:1705.11,   br:2220.97,   tr:2669.20,   tl:2354.08},{bl:1482.23,   br:2458.03,   tr:2867.11,   tl:2191.57},{bl:1269.68,   br:2695.69,   tr:3070.81,   tl:2046.81},{bl:1073.24,   br:2939.76,   tr:3280.74,   tl:1923.77},{bl:1163.64,   br:2967.90,   tr:3222.17,   tl:1812.77},{bl:1257.81,   br:3004.37,   tr:3162.12,   tl:1703.71},{bl:1356.67,   br:3046.34,   tr:3105.90,   tl:1596.98},{bl:1458.70,   br:3091.74,   tr:3053.81,   tl:1493.15},{bl:1566.26,   br:3146.05,   tr:3006.00,   tl:1392.71},{bl:1674.72,   br:3201.40,   tr:2962.68,   tl:1296.55},{bl:1786.57,   br:3257.59,   tr:2924.10,   tl:1205.80},{bl:1894.86,   br:3321.64,   tr:2890.38,   tl:1121.58},{bl:2007.54,   br:3117.27,   tr:2649.37,   tl:1320.79},{bl:2147.74,   br:2912.10,   tr:2409.71,   tl:1538.52},{bl:2307.21,   br:2714.45,   tr:2172.56,   tl:1760.92},{bl:2481.32,   br:2526.10,   tr:1938.68,   tl:1990.59},{bl:2668.88,   br:2349.28,   tr:1709.28,   tl:2224.42},{bl:2864.52,   br:2186.84,   tr:1486.64,   tl:2458.44},{bl:3066.55,   br:2042.12,   tr:1274.10,   tl:2695.97},{bl:3273.67,   br:1919.29,   tr:1077.88,   tl:2935.92},{bl:3218.25,   br:1808.12,   tr:1166.45,   tl:2967.59},{bl:3158.20,   br:1698.97,   tr:1258.78,   tl:3004.53},{bl:3101.98,   br:1592.05,   tr:1357.89,   tl:3047.57},{bl:3049.91,   br:1488.05,   tr:1459.21,   tl:3094.96},{bl:3002.14,   br:1387.52,   tr:1563.42,   tl:3146.74},{bl:2958.85,   br:1291.20,   tr:1669.52,   tl:3202.70},{bl:2920.28,   br:1200.21,   tr:1779.71,   tl:3262.61},{bl:2886.62,   br:1115.79,   tr:1893.97,   tl:3325.55},]
Computing... This may take several minutesFitness: 0.4278089 in 100
Fitness: 0.4278089 in 200
Fitness: 0.4278089 in 300
Fitness: 0.4278089 in 400
Fitness: 0.4278089 in 500
Fitness: 0.4278089 in 600
Fitness: 0.4278089 in 700
Fitness: 0.4278089 in 800
Fitness: 0.4278089 in 900
Fitness: 0.4278089 in 1000
WARNING FITNESS TOO LOW. DO NOT USE THESE CALIBRATION VALUES!
I just noticed that I do not see the new Z-axis icons mentioned i the release. I just re-uploaded the index.html and maslow.yaml files and updated the firmware again to see if they would show up but no luck. The System Satus tab shows:
FW version: FluidNC v0.74
WebUI version: github.com/MitchBradley/ESP3D-WEBUI@e85c812
