I uploaded 1.02 trough usb-c like the video tells to do, now belts a extended correctly!
starting the calibration process, the maslow sometimes retracts the bottom belts very tight and the top belts not, getting " [MSG:INFO: Requesting state change from 4 to 6]".
meanwhile the maslow just stops doing anything unless unspooling slowly all belts, the first time a tought this is normal and i just go a BIG mess with the belts pushed trough the arms in the worng way!! all my belts have now a “knick” somewhere.
This is again just frustrating, while i am waiting for the new board i can’t not even calibrate it!
my freame is horizontal w:2000 h:1250
calibration grid size. w:400 h:200 3x3
or calibration grid size. w:1000 h:600. 9x9
in both ways the problem mains the same…
just tried to upload again the files, same thing happens…
Could the calibration mode be set to vertical? In vertical mode it expects gravity to be doing some work which would result in the belts extending like that
By default is it set to horizontal no? I am almost sure i saw each time horizontal written in the settings, but have to check again this evening in the status. I never clicked on the dropdown button because i saw horizontal.
The setting will be saved, but the process of updating to 1.0 will wipe your settings which will reset it. I think that the default is horizontal, but I’m not 100% sure.
It just tensioned 3 belts and stops there unspooling the 4th, last time it unspooled all 4 belts and make a big mess! And sometimes it gives a message lime the states 4 to 6 or something.
The frame is set to horizontal.
Closing the UI, the arm still unspools and dosent stop… now i released one of the tensioned belt and realised that an other was retracting the belt the whole time
UPDATE:
installed the v.03 with the new board (without cooler on the one chip).
→ One belt bottom left sometimes not retracting (need to rectract twice)
→ extracting works
asks me to change state 3 of 3 (guess this means press calibration?)
→ press the button and then it asks me to change the state 3 of 6
I am completely lost with this machine.
This seems to be all software related problems because with each update i am getting closer.
Am i the only one that can not make work this machine?
What is state 3 of 6? I started all over again and again and always reaching to the same point.. blocked there. It isnt clear what to do, what it means, i tried every thing, just can’t get any further.
It stoped to unspool with the update thats the past. I am not a home to try but i did press the test buton 10 times already and believe that each time it tested 4 things which were good but i can‘t remember the serial
I am here again with the same old problem. Latest firmware, a pain in the ass until can get it to press the calibration button because the serial tells me that there is a problem like “low data savings’ sry cannot remember the correct word in english which was displayed.
When finally the calibration button unblocked, it moved to the right side (power plug) and started to unspool slower tan a slug. I tried to let i do its thing and just pulled the belts to prevent a misery all 2 seconds until it reached the point that the left side was unspooled completely and it started to spool in the belt in in the wrong direction.
I am still lost, just wanted to trow that thing out the window. No advance, just now the 4 arms are unspooling all togheter. Help
usually this only happens if you have the machine set vertically (like a wall)
but have the setting set to horizontal (like a floor)
This is what bar said last time, i double checked, it is set to horizontally. Im on last version v1.05.
just checking, your frame is flat on the floor, not leaning? If you have it set
in the software to horizontal, but have the frame leaning, that would cause the
symptoms you are seeing.
when the frame is flat on the floor, the belts will only feed out while you are
pulling on them.
what do you have the belt extension length set to in the 1.05 software settings?
