How many of you have your frame on casters? How well does it stay calibrated when moved? I’m considering having mine in a covered trailer. I while I understand that I will more than likely have to recalibrate after moving the trailer will it handle the smaller vibrations of movement of the suspension of the trailer when parked?
you are unlikely to have a problem, even when moving the trailer. The worm gears
in the motors aren’t going to move (and even if they did, you wouldn’t have to
recalibrate, just reset the chains). As long as the machine is at close to the
same angle.
