A common cause of this is if the Z offset for the belts is different from what
the machine thinks it is. The default values assume that the anchors are at the
level of the bottom of the sled.
are you running the maslow on the floor to calibrate? or are you running it on
top of some wasteboard?
you need to set the spoilboardthickness (go to the fluidnc tab, then the config
(round bubble on the right0 and then down about 15 or so items)
thank you for the speedy reply. i am running it on top of a wasteboard and have the anchors spaced to make them pull level with their appropriate belt spools. i will remove the spacers so that the anchors are on the floor and will set a value for the spoilboardthickness and try again. will report back
No, in that case what you want to do is to change the Z offset for each arm.
enter the height difference between the arm with the router all the way down and
the anchor (bottom of the belt connector in each case)
Looks like that seemed to solve the issue. got through calibration and saved to my .yaml and went to run my first test cut and got disconnected. rebooted and now the status is unknown so it looks like i have to go through the retract,extend, anchor point process again? is there something im missing to not have to calibrate every power up? sorry for getting off topic didnt want to start another thread
you do not need to calibrate every power up, once you have valid anchor
locations, you have two workflows to remember
if nothing goes wrong, just relax tension, disconnect the belts and then you
can either retract the belts and power off or just power off
then you power on, extend the belts (if they were retracted), connect them to
the anchors, and apply tension.
if you have a crash while moving. you will power on, retract the belts,
extend the belts, connect to the anchors, apply tension
in a crash, you may need to power on and release tension to be able to
disconnect the anchors.
now, the issue is going to be figuring out why you are getting disconnected.
there are other active threads on that topic right now, please read through them
and either ask questions there or start a new thread for your issue.
Hello, I even have a lower fitness.
maslow is anchored to the floor fixed to 3D printed ‘Triangle Anchor’s. there’s no spoilboard so the machine is directly on the floor, little bit below the anchor points. Z-axis completely down. Can someone point me in a good direction to debug? Thank you!! Maslow-serial.log (52.8 KB)
maslow is anchored to the floor fixed to 3D printed ¡Triangle Anchor¢s. there¢s no spoilboard so the machine is directly on the floor, little bit below the anchor points. Z-axis completely down. Can someone point me in a good direction to debug? Thank you!! Maslow-serial.log (52.8 KB)
v1.18 just came out, which includes some calibration fixes, try that.
I would also set the wasteboardThickness setting in the maslow.yaml, if the
surface your sled is on is below where the anchors set (and all anchors are the
same height), then this value will be negative. I doubt this is the deciding
factor here, but it can’t hurt to set this correctly.
There is nothing obvious in the logs.
are the belts pulling tight at each measurement point? if not, you may need to
increase the retraction setting.
After repairing the wire and tapping it a few times and I got the motor working again. But when I set a retraction force of 900 on this one, doesn’t engage, whereas it does at 1000. The other belts work perfectly with a retraction force of 900.
The belts are all tightly tensioned when searching for the anchor points. I could play the harp on them
The fitness isn’t quite good enough to move on to the next step, but it’s WAY better than the .02 that we were seeing in the log.
Every time that you run the anchor locating process it will improve so having a good starting point can help it to go smoother.
The next thing that I would try is to enter those values that I found in for the anchor point locations and then try again. That should give it a better starting point so hopefully the math will converge better.
To enter them you want to use this config items menu:
