Several changes made to the Maslow recently and they are garnering the best results so far.
- Installed the wooden linkage kit. (odd you can still smell the burned wood when you open the envelope it comes in) I used 220 sandpaper and some paste wax to make everything move a little smoother and easier. I used a hole saw to cut plywood plugs that I could stack to use as mounts for the mounting bolts. I also used some 2p10 glue to stick them together. If you’ve never used 2p10 you are missing out.
- installed 1.11 and used it to do calibration. Hats off to Bar the new cut pattern is miles ahead of the last. I like that it uses more of the work surface and you actually measure from one cut to the top of the workspace. great move.
I cut a 6" square on the left side of the machine toward the middle bottom you can see the location of the cut out here:
and the results are the best I’ve had so far:
I am very pleased with the results and cant wait to rework some old designs.
Here’s a pic of my shop dog, just because she’s awesome:
