Conection issues
I’m struggling with connecting to maslow. have tried maslow.local and every IP address that’s connecting to my router. I also switched off my router and connected to “maslow” but the pop-up window didn’t show up. What am I missing? can i connect to maslow via usb? is there a way to force the pop up window? I have connected to it before and it knows my wifi password… help ???
if you flash via USB, it will reset the wifi configuration. did you set it to
sta or sta → ap? if you just set it to sta, it will only try to connect to your
network, if you set it to sta → ap it will try to connect, but if it can’t, it
will create it’s own ssid.
it is possible to change the wifi settings via usb, but it’s messy, you would
need to look at the fluidNC documentation for the details of how to set that and
debug through the wifi interface.
the wifi range of the maslow is very poor, and it gets worse when the router is
running, so you may just be out of range of your home system
Any BT or WiFi connection with Maslow post-processor for LightBurn?
Do you see the blue LED blinking? If it’s blinking that means the machine is connected to your wifi network and is blinking out it’s IP address. If it’s not blinking that means it is not connected to your home network and is making it’s own “maslow” wifi network for you to connect to
yes, and i tried the ip adress on chrome, firefox and on my phone. however i also (after shutting down the router) tried to connect to the “maslow” network however i didn’t get the pop up window (I have tried this several times, and I would also restart my computer and Maslow).
I’m unsure of what “BT” stands for… Blue tooth? there is a wifi connection with maslow (when the router is off) and with my router (as there is a flashing blue light) does the post-processor “light burn” allow me to connect to maslow in a different manner? (compared to the ip address or the "maslow network, way of getting to fluid)
I might have to go through the usb flash game
I’m a little hesitant, as I bricked my last board that way (but I’m pretty sure that was coz i deleted some important files I shouldn’t have)
I didn’t change the sta/ap button (didn’t know there was one) but it makes its own ip and when the router is disconnected, it make the “maslow” wifi
do you have any links to the fluid documentation for how to connect via usb? last time i used this video https://www.youtube.com/watch?v=od7DpdLel6A&t=3s
cancel that, I unpluged it from the router so it was easier to work with… and now it flashes red from “led 2” and there is no “maslow” wifi… guess this means I do the “usb flash” unless you have an alternate option. I have done the usb flash before, (I did brick the last board doing it, but i did delete a bunch of files I probably shouldn’t have)
