What I learned sofar: Nylon roller or 2nd sprocket close to main dc motor sprocket works well to keep chain on dc motor sprocket and prevent gear slip. Bungee works well to keep slack chain tensioned and out of the way, counterweight gives a more constant load but operates in a different plane.
As a recreational sailor I am familiar with pulley systems. It would be very useful to use a “double pulley system” in my view. A double pulley system will reduce the amount of vertical travel of the counterweights to the horizontal movement of the slack chain.
- Google “double pulley with becket”. You will need two of these for a single chain, so four in total for your Maslow.
- This is how it works:
Note in this example the rope is looped four times between the pulleys. This will result in a 4-to-1 ratio effort reduction.
What does this mean?
It will take 4 times less effort to lift the weight. If you pull in 4 meters of rope, the weight will have only travelled 1 meter. So you basically sacrifice length or rope for effort required and vice versa.
How is this useful?
Using a pulley system with a 4 times heavier weight than normal you will have the same functionality as using a single rope without pulley system. The benefit of a pulley system is that you can store 4 times the amount of bungee cord in the same area. This four times longer bungee cord is more evenly and less extremely stretched and will last longer / will have a more consistent pulling force. If you are using counterweights instead of a bungee cord, the benefit of using pulleys is that it reduces the vertical travel of a counterweight by a factor four.
Note that at least one of the pulleys will need to come with a ‘becket’. Having a becket on the second pulley is ‘nice to have’ as it keeps parts interchangeable and does not negatively impact the setup. Using a pulley that can freely rotate along its mounting point is preferred when using an (angled) Maslow frame with vertical counterweights.
In the sailing world, Ronstan and Harken brand stainless steel blocks / pulleys are commonly used (but expensive).
