Hi,
I am trying to get my setup calibrated with Makerverse and Due. I’ve probably done a dozen or more edge calibrations but can’t get better than 16.7mm accuracy. Sometimes it even gets worse after calibration. Tells me, my setup is skewed by 8mm clockwise, and that my stock is 1.5xxx mm to the left from the center of the workspace.
If repeated calibration will eventually help me, I will continue to do so, but at the moment the accuracy did get a bit worse (16.8 last one).
If there are other things I should do, I would appreciate a hint (or two)
Thank you.
marie.o
PS: In case it helps: My frame is the screwed together kind, and when I lower the chains after the chain length check of the calibration process, the pin goes straight down.
