The machine was decalibrated and when trying to calibrate it again it no longer moved.
Has this happened to someone? What could be going wrong? How can I verify that the motors and the board are ok? Please help me, I’m worried
if it lost power, you will need to reset the chains
set the sprockets so that they have a tooth at 12 o
clock and then put the link that you marked as part of the calibration on that
tooth.
if you didn’t mark a link, then you will need to go through pretty much the
entire calibration again.
Yes, I tried but the motors do not move at all, is it possible that they have been damaged by the loss of energy? Is there a way to test if the motors are operational?
Thanks for the help anyway.
what software are you using to drive your machine? there should be a test motors
function.
